Page 1 of 2
And on the subject of EEC terminals...
Posted: 2021 Feb 26, 09:33
by MyShrink66
Is there a source for EEC-IV 60 pin female (can we still say that?) terminals. I had a pretty good stock before RJM disappeared but after a couple of custom harnesses my supply is about dry.
Re: And on the subject of EEC terminals...
Posted: 2021 Mar 02, 10:15
by Trogdor
I looked last year for some when I was doing my electric fan install and could not find any, all I found where ones that where either too big or too small. I actually bought them and physically tried them, but no dice. In the end I found someone that was selling an EEC-IV connector with the wires still attached and wound up using some of those for my fan and T4M0 conversion. But if anyone knows of a source I would not mind buying some just to have in my toolbox.
Posted: 2021 Mar 02, 11:40
thats what I do I jack them from a junk harness
Posted: 2021 Mar 02, 21:49
by MyShrink66
Me too since I ran out of my supply of RJM's stuff. Thought I had found gold at Terminal Supply where I get a lot of my harness stuff but no Joy. On my swap from A9M to CBAZA I did a complete re-pin out. Unfortunately I ran into brittle terminal lock trouble and just about painted myself into a major corner. At that point I interposed Delphi connectors after the EEC connector and did my pin-out swap through them. Now I can change it back or whatever without worrying about broken terminal locks. Probably not a bad idea to grab any naked 60 pin connectors you might find...even at the stupid price. They won't be available for ever.
Posted: 2021 Mar 04, 17:42
by Trogdor
I've got a couple of terminal locks that are broken. Other than super glue, and ingenious ways to fix them?
Posted: 2021 Mar 16, 23:14
by danielt
These are for the EEC-IV 60 pin plug.
Male terminals:
https://www.clipsandfasteners.com/Wedge ... a14887.htm
Female terminals:
https://www.clipsandfasteners.com/Wedge ... a14888.htm
The EEC-V plug is smaller diameter. The same company sells both.
Regards,
Daniel
Posted: 2021 Mar 16, 23:26
by motorhead1991
Those are the .110 pins, not the .060.
EEC-V uses an 0.040 size pin IIRC.
Posted: 2021 Mar 17, 15:18
by danielt
I believe EEC-V uses the 0.060 pins. I ordered those first and they were too small.
Posted: 2021 Mar 21, 12:57
by Trogdor
For the EEC-IV the 0.060 pins are too small and the 0.110 pins are too big. We are in a Goldilocks situation here.
Posted: 2021 Mar 21, 19:05
by dleach1407
The manufacturer stopped making the ones you looking for. This information was posted on the old forums but it appears that information was lost with the conversion to this new forum. They have been discontinued for like 6 years now
