Using New XDF
subforum for requesting current tune review services
Not happy with your current tune? Or if you just want
a 2nd opinion, this is the place for it
Using New XDF
Unread postby 93svt » Thu Jul 09, 2020 12:02 am
I am trying to convert to the new XDF but my numbers are very weird. Not sure if I am doing it correctly. I may have scaled my tune wrong but the car runs very well.
I have an HPX-E but when I try to convert things look off. Attached is the tune that is in the car now
Thanks for any help
93svt
Power Poster
Vehicle Information: 1993 cobra #1675
Paxton
HPX-E MAF
A9L2!
Vehicle 2 Information: 2018 Jeep Wrangler
Vehicle 3 Information: 97 F150
Additional Vehicles: 2014 BMW 335i
Re: Using New XDF
Unread postby 93svt » Thu Jul 09, 2020 3:59 pm
ok, I may have converted it correctly my injector data came out close to published info and the MAF is about 2.1% higher but the cid was showing 312.
is this because I originally scaled wrong?
I set back to 302
A little worried about changing but the latest looks very nice being that you can view actual values.
The last time I thought I scaled wrong I redid new tune and it would not even get in to enough load to go rich for the boost
here is the new converted tune
93svt
Power Poster
Paxton
HPX-E MAF
A9L2!
Re: Using New XDF
Unread postby decipha » Mon Jul 13, 2020 3:47 pm
read the comments for the warning high slope scalar and double check
this will help too
viewtopic.php?f=18&t=3552
Name: Michael Decipha Ponto
06 Chrysler 300 AWD - Sharifa
Re: Using New XDF
Unread postby 93svt » Tue Jul 14, 2020 10:18 am
I sent you a PM watcha think
93svt
Power Poster
Paxton
HPX-E MAF
A9L2!
Re: Using New XDF
Unread postby decipha » Tue Jul 14, 2020 11:08 am
In order for me to do anything I'd basically have to tune it no other option than a premium member.
http://www.efidynotuning.com/tune.htm
Re: Using New XDF
Unread postby 93svt » Tue Jul 14, 2020 2:28 pm
Gotcha. Did you happen to look at the 2 tunes and see if it was converted properly?
I think I did
93svt
Power Poster
Paxton
HPX-E MAF
A9L2!
Re: Using New XDF
Unread postby 93svt » Tue Jul 14, 2020 9:58 pm
The main reason I wanted you to take a look is that a few values came back weird after converting to new XDF
like a the CID was 312
the MAF was 4080, not 3999
just making sure am on the right track with current XDF
Also, I do not mind paying for something I need to so if you look at the tune and recommend you redoing i will
93svt
Power Poster
Paxton
HPX-E MAF
A9L2!
Re: Using New XDF
Unread postby decipha » Wed Jul 15, 2020 6:13 pm
that means you changed either the injector high slope or the k-constant after making those changes. K-constant and high slope have to be changed first as specified in the comments.
Re: Using New XDF
Unread postby 93svt » Wed Jul 15, 2020 9:37 pm
I have followed this
If you have a functioning tune and want to update it so un-scaled values are shown then change the SP** AHISL scalar to your actual injector high slope value for your injectors (unscaled value).
change the High slope to 46.818
then I get CID 312
MAF tops at 4087
Then I copy all that change K Constant to 30 values change but then I renter what was in there before changing K Constant
Wrong?
Did I just scale wrong In the first place? i am guessing i need to put values like 302 for CID and the worksheet for an HPX-E with a 85MM housing tops at 3999
and dial back in?
93svt
Power Poster
Paxton
HPX-E MAF
A9L2!
Re: Using New XDF
Unread postby decipha » Thu Jul 16, 2020 10:47 am
yeah you scaled wrong in the first place
no big dea. Just set the k-constant to 30 and plug in the actual high slope and all the rest of the injector data, sarchg, and maf and you can proceed.
Re: Using New XDF
Unread postby 93svt » Thu Jul 16, 2020 5:12 pm
Gotcha
Looks like everything came out to maybe 2-4% off so should be a big deal getting it lined back up.
Thanks for the help!
Edit: forgot to ask looks like the new xdf doesn't have the MAF histogram I have been using. What is the one I should be using now
93svt
Power Poster
Paxton
HPX-E MAF
A9L2!
Re: Using New XDF
Unread postby decipha » Thu Jul 16, 2020 7:50 pm
it has it still
Re: Using New XDF
Unread postby 93svt » Thu Jul 16, 2020 9:24 pm
If it's the Hist_Maf_Err (hego Only) it just looked different and I was checking. So now do the extra rows show the error calculated after X time at that AD Count?
93svt
Power Poster
Paxton
HPX-E MAF
A9L2!
Re: Using New XDF
Unread postby decipha » Fri Jul 17, 2020 9:52 am
no one of them is APT to filter throttle
one is to filter fuel pressure for eec-v
Re: Using New XDF
Unread postby 93svt » Sun Jul 19, 2020 3:09 pm
OK
Loaded in new XDF tune cranked up fine had to adjust MAF a tad to get fuel error at 1.00 I have not driven just free rev to adjust but the question is
I had to fiddle with idle screw a tad trying to dial in ipsibr but seems kinda finicky now. still, trying to target 0.000 right?
it seems to idle lower now and that is fine but is a negative number bad I see is duty go yellow? I raise a little and the ispibr goes red but just seems harder to achieve 0
93svt
Power Poster
Paxton
HPX-E MAF
A9L2!
Re: Using New XDF
Unread postby decipha » Sun Jul 19, 2020 4:04 pm
its up to you as the tuner to get the best you can or til where your satisfied with it
Re: Using New XDF
Unread postby 93svt » Sun Jul 19, 2020 4:25 pm
Seems to be ok with new xdf but so I am not going in circles negative means I need to increase idle screw?
93svt
Power Poster
Paxton
HPX-E MAF
A9L2!
Re: Using New XDF
Unread postby decipha » Sun Jul 19, 2020 4:28 pm
no negative means the isc is closing to reach idle
at hot stable idle that means the throttle stop needs to be closed
during warm up that means the isc multiplier needs to come down
Re: Using New XDF
Unread postby 93svt » Sun Jul 19, 2020 5:20 pm
Yeh, I think I had a brain fart I meant to say decrease idle.
I will say i need to dial fuel back in but seems very close and I am not sure what has change from the XDF I was using but dang it runs good.
I can cruise in the neighborhood at like 1200 rpm no surge
Also is this correct looks weird to me
Edit : it's a pic of the table and it has some values I dont understand like 4000 and 7000 as row 3 same as when I open original A9l2 but may be wrong just checking
93svt
Power Poster
Paxton
HPX-E MAF
A9L2!
Re: Using New XDF
Unread postby 93svt » Tue Jul 21, 2020 7:46 am
I figured I would make it easier and not have to download pic
ATRM3 Row
8 65535 = 5
7 255 = 5
6 35 = 3
5 5 = 0
4 0 = 0
3 65535 = 3
2 7000 = 3
1 4000 = 0
And the top of the table (Z_XFN1861 EXT) does not show temp its blank? I know its a Patch just making sure it's not corrupt or anything
93svt
Power Poster
Paxton
HPX-E MAF
A9L2!
Re: Using New XDF
Unread postby decipha » Tue Jul 21, 2020 10:11 am
your looking at the wrong function that one obviously isnt used
Re: Using New XDF
Unread postby 93svt » Tue Jul 21, 2020 10:37 am
Sorry I may be confused. So I use the one in the unsued folder? It says that they are disabled if patched and A9l2 is patched
I am in the tuning folder so what are the correct ones to adjust
I see if you adjust one it changes the other one FN1861
93svt
Power Poster
Paxton
HPX-E MAF
A9L2!
Re: Using New XDF
Unread postby decipha » Wed Jul 22, 2020 10:47 am
the one that you use is dependent upon the patches enabled in the tune
if one looks jacked up use the other
Re: Using New XDF
Unread postby 93svt » Wed Jul 22, 2020 10:59 am
I have compared it to the latest download and all patches match. seems to do fine right now may need a tad more start idle air seems lower than the previous XDF I was using.
One more thing about using Tuner Pro with the XDF/ADX you have. Is there the little circle thing that shows you where you are in a table?
Thanks for your help!
93svt
Power Poster
Paxton
HPX-E MAF
A9L2!
Re: Using New XDF
Unread postby decipha » Wed Jul 22, 2020 11:01 am
thats the trace, I dont think I have it setup.
Re: Using New XDF
Unread postby 93svt » Wed Jul 22, 2020 5:26 pm
Would you mind taking a quick peek at my tune? I have the fuel close after converting. I can dial it in but I have compared patches and all looks good but the ISC startup stuff. I have even seen a pic on the forum with the 1861-ext shows temps but mine stops at 200 looks like I lost the over temp stuff.
I even redownloaded the file off-website and same thing.
if you would just check the X-Y stuff
93svt
Power Poster
Paxton
HPX-E MAF
A9L2!
Re: Using New XDF
Unread postby decipha » Thu Jul 23, 2020 3:20 pm
I removed the 242 column since its not needed
Re: Using New XDF
Unread postby 93svt » Thu Jul 23, 2020 6:44 pm
it just seems like there is less aggressive ISC startup than what I am used to with the version I was using.
if that's normal good with me
93svt
Power Poster
Paxton
HPX-E MAF
A9L2!
Re: Using New XDF
Unread postby decipha » Sun Jul 26, 2020 11:19 am
yep
it doesnt matter though since it will all be dialed in
Re: Using New XDF
Unread postby 93svt » Sat Aug 01, 2020 11:39 am
I got a question for you.
When I convert my values i am currently using in my a9l2 tune to the new xdf/adx the fuel error goes up to like 1.08 ish even if I log 1+2 or just error 1. Another thing it randomly jumps back in to ol like something has failed.
Does not crank as well and I have adjusted the throttle stop just like I would before. I noticed hego 2 looks lazy. But here is the kicker when I go back to old tune It does none of those things. And the error is .999 to 1.02 pretty much through out MAF.
I ordered new hegos just incase mine are original 75000 miles.
Any suggestions?
93svt
Power Poster
Paxton
HPX-E MAF
A9L2!
Re: Using New XDF
Unread postby decipha » Sat Aug 01, 2020 12:49 pm
use the old tune
Re: Using New XDF
Unread postby 93svt » Sat Aug 01, 2020 4:07 pm
Yeh but why would it act different with the same values. Even did a xcel File To calculate it for me so nithung is missed maf,injectors,breakpoints,sarchg etc
another thing is kamrf 1 will be .998 2 will go to 1.07 but not with old xdf and base file
93svt
Power Poster
Paxton
HPX-E MAF
A9L2!
Re: Using New XDF
Unread postby decipha » Sat Aug 01, 2020 7:31 pm
odd indeed
Return to <<--Tune Review-->>
