Spark map check
Spark map check
How do my decel and PT areas look here? (Aside from the high up decel retard)Making sure im not majorly off the mark here.
Re: Spark map check
Should add the fuel and engine+mods I guess too lol.
e10 91 octane PI 4.6 crower stage 2 blower cams Dur @ .050” Lift: 216°/216° Gross Lift: .581”/.581” LSA: 114° ported FRP SVO intake manifold, LT's through OR x pipe
Re: Spark map check
post your current tune file
Re: Spark map check
Sure, ive since changed it a bit , dang thing rattles like a rattle trap and Ill periodically convince myself its low load ping.
Also figured out the K constant stuff finally lol. Scaled the MAF weird afterwards, but wideband still says its mostly on the money.
Funnily enough, of course a lot of your datalogging stuff started working afterwards, and while the MAF readings seen scaled up quite a bit afterwards (250'ish G/S pre K constant vs 330+ G/S after 30 k constant) versus prior, your ADX's whp math matched what I calculated based off the old unscaled MAF peak #'s
- 9.17 24# INJECTORS.bin
- (256 KiB) Downloaded 307 times
