EFI-SD40a
S/D specific subforum for the Gen-1 Lightnings,
88- Tbird/Stang/Lincoln/Mercury, RV's, and Trucks.
Re: EFI-SD40a
Unread postby decipha » Thu Jun 04, 2020 3:10 am
attached
LMK how goes it and post back with a log.
Name: Michael Decipha Ponto
06 Chrysler 300 AWD - Sharifa
Re: EFI-SD40a
Unread postby efloth » Thu Jun 04, 2020 6:36 pm
Thanks for your efforts but something is off pretty bad. Check engine light is flickering and rpm is sporadic (1000-2000) and missing terribly. I tried to log it but nothing populated in the dash and it was so violent I just shut her down. I checked PIP Degrees is 120 but thinking something is still set up for a v8 somewhere.
Vehicle Information: 1991 F150 4.9L on E85
Siemens Deka 80LB Injectors
EFI-SD40a
J1X
Re: EFI-SD40a
Unread postby decipha » Fri Jun 05, 2020 3:19 am
no that means the ecu is resetting because its corrupt. i overwrote 1 byte on my custom code for the larger VE table.
here give this a try.
Re: EFI-SD40a
Unread postby efloth » Fri Jun 05, 2020 10:57 am
Hey that 1 byte was important :lol:
MAP is weird and is a pretty major performance/driveability regression but it works! I made it short cause running rich and have the nice sulfur smell from the cats. Not sure if the 02 is completely dead now or if it is OL due to MAP sensor reading off. Had a check engine light for bit before I started logging but it went off.
EFI-SD40a
J1X
Re: EFI-SD40a
Unread postby efloth » Wed Jun 10, 2020 1:08 am
I got the new o2 installed today and started working on the new strategy. Making good progress but I am a bit confused about the new injector slope setup. I ended up changing the old value to get it running right. The new one did not seem to have an effect on lambse.
EFI-SD40a
J1X
Re: EFI-SD40a
Unread postby decipha » Wed Jun 10, 2020 4:24 pm
yea i fixed map already was a byte i changed to word.
correct the newer ahisl is for scaling percentage which speed desnsity doesnt support. I need to update the comments and title for it.
Re: EFI-SD40a
Unread postby JETFAST » Fri Jun 12, 2020 7:44 am
decipha wrote:
In any case I have attached a startup tune for the straight 6. You should be able to load this in and begin dialing it in.
if you have a manual trans and not an e4od then disable the trans
1993 F-150 4.9 I6 5 SPEED MANUAL OD
EEC-IV EFI-SD47A
F3TE-12A650-ABA
CAW0/GAS0
disabled the trans, and flashed to a chip this morning, just to see if it would even run.
Happy to report my shop truck runs pretty damn good.
work on getting the QH on next and see what the logs say.
thank you Decipha.
JETFAST
Vehicle Information: Horsepower Breader
Re: EFI-SD40a
Unread postby decipha » Fri Jun 12, 2020 7:50 am
yea no prob
Re: EFI-SD40a
Unread postby efloth » Sun Jun 14, 2020 6:58 pm
Getting great results with the new strategy. Thank you. FYI it does not seem to effect anything but MAP is still jumping all over the place. Also I am having trouble taming the idle now. Is there anything I should try before going through the mechanical idle setup? I noticed my throttle plates have a small hole drilled in them. Should I sorry about plugging them? Others have reported it helping. Idle cold seems fine after a minute or so but once she warms up I am at 1400-1500rpm.
EFI-SD40a
J1X
Re: EFI-SD40a
Unread postby decipha » Sun Jun 14, 2020 7:30 pm
i fixed the map just never posted an adx for it, i'll post you one when i get to my laptop
how do u like the large ve table?
you need to dial in the idle air function and isc multiplier
Re: EFI-SD40a
Unread postby efloth » Sun Jun 14, 2020 8:02 pm
It's way better man! After a minute or two of explaining I had my 11 year old boy dialing in the fuel while we were cruising down the highway ;)
EFI-SD40a
J1X
Re: EFI-SD40a
Unread postby decipha » Mon Jun 15, 2020 8:00 am
u do know the histogram does it for you
Re: EFI-SD40a
Unread postby efloth » Mon Jun 15, 2020 5:08 pm
Is this what you are referring to?
If using TunerPro RT, I have setup a histogram to dial in FN1036. Simply copy and paste that table into your tune along with the axis scaling.
EFI-SD40a
J1X
Re: EFI-SD40a
Unread postby decipha » Mon Jun 15, 2020 10:07 pm
no fn1036 is for inferred load
the VE table histograms is what you want, it gives you the correction value for each cell
open the histo and set it to running average thrn go for a short drive in varying conditions
apply the errors from the tablrme to the ve table and then repeat til all the errors are between 1 and 1.05
Re: EFI-SD40a
Unread postby efloth » Tue Jun 16, 2020 3:01 am
Got it, that's what I've been doing. It sounded like you were saying there was some automagical way for tuner pro to update the ve table with the histogram (feature request :D). Call me lazy but there are a lot of cells that need correction so I am just setting up an excel doc to make the adjustments in bulk. The histogram has rpm columns that aren't in the ve table so makes it a little more difficult.
EFI-SD40a
J1X
Re: EFI-SD40a
Unread postby decipha » Tue Jun 16, 2020 6:52 am
yea thats required to improve the accuracy of each cell
Re: EFI-SD40a
Unread postby efloth » Tue Jun 16, 2020 6:21 pm
This should help make it easier for others on A1C (easily adaptable for other strats). Three sheet excel doc for simple copy and paste from TunerPro RT to generate completely updated VE table in seconds. I checked for errors but please confirm this looks good to you.
EFI-SD40a
J1X
Re: EFI-SD40a
Unread postby efloth » Thu Jun 18, 2020 11:18 am
Working on mechanical Idle and not seeing FN800. Does it not apply to SD?
EFI-SD40a
J1X
Re: EFI-SD40a
Unread postby decipha » Thu Jun 18, 2020 12:54 pm
i'll add it in. In the older strats is a function not a table.
Re: EFI-SD40a
Unread postby efloth » Mon Jun 22, 2020 2:09 pm
awesome. I am still struggling to get a consistent idle after several drive cycles. Seems perfect at times and then today back up to 1400-1500
EFI-SD40a
J1X
Re: EFI-SD40a
Unread postby JETFAST » Mon Jun 22, 2020 2:33 pm
I was having a hard time getting my tb set to idle and start good. got the QH going on the data, and first thing i adjusted was lowering SARCHG to 4.9 the map smoothed out, and i was able to set the TB correctly. bout to head out for a test.
***EDIT**** I left it at 400 CI and lowered SARCHG from 5.8 to 4.9 made a huge difference in start, idle, and drivability.
JETFAST
Re: EFI-SD40a
Unread postby efloth » Mon Jun 22, 2020 4:59 pm
Interesting. I checked and Eric_startup_B.bin has SARCHG CID = 400CI and BASEMD = 265.3505CI
EFI-SD40a
J1X
Re: EFI-SD40a
Unread postby JETFAST » Tue Jun 23, 2020 10:59 am
I am running the sdx4_6cyl_test.bin
JETFAST
Re: EFI-SD40a
Unread postby efloth » Tue Jun 23, 2020 4:12 pm
It appears changing the engine size has a direct impact on fuel calculations so I would image a change in the right direction would improve performance, idle and drivability. Decipha would need to clarify if it has any other implications.
EFI-SD40a
J1X
Re: EFI-SD40a
Unread postby JETFAST » Tue Jun 23, 2020 9:03 pm
following the cubic inch of 400 that calculates more to 6.6 liters not 5.8. so i started lowering that value, and am down to 4.3 now. best this truck has ever run. pretty amazing honestly. i can actually stay in OD now at 70 with a 2.73 final and pull a grade with out the need to down shift.
JETFAST
Re: EFI-SD40a
Unread postby efloth » Sat Jun 27, 2020 12:42 am
Glad to hear that worked well for you. I have been playing with engine size and once changing it I am having to dial in the VE table again. I don't know enough about other effects this might have to feel comfortable setting it arbitrarily. Performance on the stock inline 6 with 80lb injectors on e85 is definitely a major upgrade. Fuel economy is only down about 10% highway and 20% in the hills. I assume the advanced timing makes mpg better than the 30% loss I expected. Mechanical Idle settings have tamed light throttle drivability and make is a lot more predictable in low rpm pulls up the driveway.
Still fighting with the new A1C strategy in regards to OL commanded lambse being locked at 1. I tried setting the OL fuel to 0.8 across the board without any effect. I am staying out of WOT for now. The 80s @ 58 psi are have some dwell at low load but I have the fuel dialed in to the point where VE histogram stays mostly between .9 and 1.05. I am not sure if this can be improved without lowering fuel pressure. The only other issue is inconsistent ldle. Just waiting for FN800 to be added before I mess with it any more. Hoping to finish this baby up soon and post a good tune file.
EFI-SD40a
J1X
Re: EFI-SD40a
Unread postby decipha » Wed Jul 01, 2020 11:25 pm
new A1C is posted in downloads with FN800 added. FN800 cannot cause idle consistencies though.
FN820B needs to be set to all 1's otherwise you will have idle oscillations. That's most likely your idle issues.
OL should be at 1.000 lambse that's what I set them for with the base fuel table at all 1's. On speed density strats I use the WOT function FN303 to set the commanded lambse at WOT. You shouldn't be in open loop otherwise. Its most ideal to use throttle for enrichment on speed density since its much more consistent than map.
Re: EFI-SD40a
Unread postby efloth » Thu Jul 02, 2020 2:48 pm
Thanks! I will start working with this tonight. I downloaded the new files. Just curious what the difference between A1C.bin and Z2D1.bin and which one I should use. Both are in A1C_56k.zip
Also should I disregard the x-axis weirdness in the screenshot?
EFI-SD40a
J1X
Re: EFI-SD40a
Unread postby wwhite » Thu Jul 02, 2020 4:33 pm
The A1C is for a 6cyl.
The Z2D1 is for 8cyl 302ci.
I think the x-axis is missing some scaling in the XDF, or the extended VE patch isn't working right. I'm sure he'll fix that up.
I have a 8cyl 351w, just have to figure out all scalars I need to update, and will be trying out this tune as well.
Vehicle Information: 1994 Ford F150, SD KID1, TunerPro-RT, QH
351w, long tubes, eddy 3881, XE258HR-12
Vehicle 2 Information: 1964 M100 460, short box
Vehicle 3 Information: 1964 Meteor 390, 2dr, breezeway
Additional Vehicles: 1978 Alfa GTV spica
1978 Alfa spider
Re: EFI-SD40a
Unread postby decipha » Thu Jul 02, 2020 4:35 pm
neither is for a v6 they are borh 5.0s
dont use either why would you? continue with your existing tune.
for a 351 you simply change the engine size to 351.
Re: EFI-SD40a
Unread postby efloth » Thu Jul 02, 2020 6:07 pm
Got it thanks. You added to/fixed the definition files not the bin :)
EFI-SD40a
J1X
Re: EFI-SD40a
Unread postby efloth » Sun Jul 05, 2020 11:08 pm
Still fighting idle issues. I am having trouble interpreting all of the fn800 stuff. Setting throtlebody airmass appears to be the only way to tame it right now. any help with this would be appreciated.
Allow 0% ISCDC at 0 lbs/hr, remove clip of 10%, Clip max ISCDC to 98%, reduce 100% values
Here is what I have right now for FN800
0.045   0.20
0.153   0.30
0.216   0.35
0.324   0.40
0.981   0.60
1.836   0.80
2.025   0.90
2.160   0.98
14.400   0.98
EFI-SD40a
J1X
Re: EFI-SD40a
Unread postby decipha » Sun Jul 05, 2020 11:14 pm
looks good
Re: EFI-SD40a
Unread postby efloth » Thu Jul 23, 2020 11:16 am
Finally got the idle tamed. Replaced faulty TPS and IAC and soldered the holes in the throttle blades. DSDRPM and N are still off by 1-200 rpm but ISCDTY is 40%. With mechanical Idle is it appropriate to increase Throttle body airmass to close IAC and reach desired RPM? Is there a better way? My set screw is almost completely out.
EFI-SD40a
J1X
Re: EFI-SD40a
Unread postby decipha » Thu Jul 23, 2020 3:15 pm
iscdc high means the theottle body needs to be opened to give it more air
no, the throttle body airmass must always be 0
Re: EFI-SD40a
Unread postby efloth » Tue Jul 28, 2020 2:00 pm
I noticed PFEHP - EGR Type SW is set to 2 and the notes suggest this is not a good idea. I have it running almost perfectly except for surging/missing at very light light throttle. Any direction here would be appreciated.
EFI-SD40a
J1X
Re: EFI-SD40a
Unread postby decipha » Tue Jul 28, 2020 6:02 pm
re enable it and see it it runs better, if its unchanged then you can disable it again if you wish
Re: EFI-SD40a
Unread postby efloth » Thu Jul 30, 2020 11:09 am
Wow that smoothed it right out. Almost completely satisfied with this tune. Pulls like never before. :)
I do occasionally get a check engine light for a short period of time usually when cold. Is there a simple way to pull the codes in tunerpro or should I just get a ODB1 scanner?
EFI-SD40a
J1X
Re: EFI-SD40a
Unread postby decipha » Thu Jul 30, 2020 11:18 am
neither, you have to jump off the STI and count the flashes
Re: EFI-SD40a
Unread postby JETFAST » Sat Aug 01, 2020 11:52 pm
Got a new turbo muffler.
JETFAST
PreviousNext
Return to Speed Density Tuning
