SAD 806x Disassembler
Re: SAD 806x Disassembler
Unread postby Pym » Thu Nov 29, 2018 7:10 am
New version is released.
Still on 1.2 but with today date (I call it 1.2e).
Still some kind of pre-release for 1.3 version.
- Structures analysis algorithm has evolved (second version).
- Signatures are now labelled Routines Signatures.
- Elements Signatures part is added (and pre-filled with MAF Transfer signature).
- Binaries comparison is now available after disassembly (to provide already identified elements list, when they are in difference).
Many other changes are included :
- Signatures can now generate BitFlags.
- Short Labels and Labels conflicts are now managed.
- Other corrections done for more stability, recognition.
Sources will follow, if you find this version stable enough.
Pym
Hacker
Vehicle Information: Ford(EU) 91 Fiesta RS Turbo / EEC IV VM120 0FAB
TunerPro on Moates chips
Vehicle 2 Information: Ford(EU) 97 Puma 1.7 VCT / EEC V LP2-110 MUFF AXPDCB4
Vehicle 3 Information: Ford(EU) 97 Mondeo V / EEC V MLP-427 REED ATAFHE3
Additional Vehicles: Ford(EU) 91 Fiesta XR2i / EEC IV SD111 1AFA
Ford(EU) 98 Cougar V6 / EEC V ?
Unread postby jsa » Thu Nov 29, 2018 11:42 am
Thank you Pym.
Cheers
John
Power Poster
EEC-IV GHAJ0
ANTI, COSY, QUIK or CARD
SMD-490, SMD-190
Unread postby decipha » Thu Nov 29, 2018 11:58 am
excellent, ill give it a whirl soon as time permits?
Name: Michael Decipha Ponto
06 Chrysler 300 AWD - Sharifa
Unread postby decipha » Sat Dec 15, 2018 11:32 am
i cant get it to work, wont let me define the range for banks
see attached
Unread postby Pym » Sat Dec 15, 2018 5:02 pm
SAD 806x does not permit to define range for banks, it autodetects it and it does the job on cdan4, that is what I can see, no ?
Pym
Hacker
Unread postby decipha » Sun Dec 16, 2018 12:22 pm
no its erroring out, see the attached zip with bin
Unread postby Pym » Sun Dec 16, 2018 4:00 pm
1 error on disassembly and 3 on output, I think it is errors we had already talked about.
Result seems acceptable for me. I will have a deeper look on these errors to be sure.
Pym
Hacker
Unread postby Pym » Mon May 27, 2019 12:15 pm
Hi all,
just to say I am currently developing the new version of the disassembler. In fact no, I am testing it.
The purpose for the 1.3 version is to make S6x creation much easier (and for sure to correct the maximum number of bugs).
When working on some disassembly, I have seen that some updates could speed up the work.
So interface is easier to use and many tools have been added for binary/strategy comparison, including 2d map and setup copy.
I will tell you more on that quickly.
Pym
Hacker
Unread postby jsa » Mon May 27, 2019 4:19 pm
Sounds like some great feature additions.
Cheers
John
Power Poster
EEC-IV GHAJ0
SMD-490, SMD-190
Unread postby Pym » Tue Jun 04, 2019 1:20 am
Some examples for new features in version 1.3 :
- Menu on items have been extended (with New or Paste options). Really useful when working on the end of a list with thousand items.
- New option in Menu items : Paste and overwrite. Where paste just paste a new item with a defaulted address, Paste and overwrite paste on current address.
It permits to copy from another item or another strategy, without losing address. For example by creating quickly a new defaulted item with just the right address.
You paste on it and nothing else has to be done.
- When filling items details, a new keyboard shortcut permits to give uppercase or lowercase on the selected text (Ctrl-Shift-U for upper or Ctrl-U for lower).
- Registers can now be created with '+' character. For example [Ra3+12] has to use address a3+12.
- Registers have now their specific Byte label and Word label if required.
- Little trick when importing from TunerPro, when TunerPro Label start with (for example) FN0036 - MAF Transfer,
first part before '-' goes to Short Label (FN0036) and second part (after '-') goes to Label (MAF Transfer).
- 'Search Signature' is a new added tools to test a signature or search for it.
- 'Comparisons' is a new sub menu in tools available after disassembly. It will give more details.
The main feature is the Comparisons tool set.
When disassembling more than one strategy in the same time, logically they are really near.
In this case creating signatures takes too much time and is not probably the first thing to do.
- When binaries are on the same strategy, the main thing to know is 'What are the differences' and for that you will find option 'Binaries Comparison (Same definition)'.
It will provide you all identified elements that have changed values between both binaries.
- When strategies are different and you have habit to work with 2d charts to compare data, 'Calibration Chart View' is a good starting point.
To get better results, the best thing is to have a compared binary with a detailled s6x (you know, in the same folder, with the same name).
Labels will be dispatched on chart and when clicking you will see what is the related item.
Still when strategies are different the best tool set is 'Routines Comparison'.
- 'Export Skeleton' option, permits to generate a routines skeleton from current strategy, to be compared later.
- 'Compare Skeleton' option, permits to compare a routines skeleton file to the current strategy.
The purpose of this option is to identify similar routines between 2 strategies, based on probabilities. A report is generated for text analysis.
- 'Compare Binaries' option, is an all in one functionality, because it generates and compare directly strategies routines skeletons.
It works exactly like previous functionality, but in addition to similar routines identification, it does the job on included items too.
Included items could be registers, tables, functions, structures or scalars and just by using context menu on item,
you can get the other setup directly (just check probability or occurrences info before).
You can do it for routines too or for a set of items.
Similar items identification works really well and can be applied directly, but I still have a issue for Registers and Bit Flags.
For Registers, direct info copy is a bit risky when strategy has different meanings for Byte and Word versions of the register.
For Registers used as Bit Flags, direct info copy is a bit risky too, because Bit Flags are often some kind of pool of registers.
for example, in strategy A has BF Ra1 0=>7, Ra2 0=>7
strategy B will have Re4.B0 = Ra1.B0, but does not contain Ra1.B4 so Re4.B4 = Ra1.B5, ... Re5.B7 = Ra2.B6 and to end Re6.B1 = Ra2.B7
Can you really say that Re4 = Ra1, Re5 = Ra2 ? because Re6.B1 = Ra2.B7.
To finish, this is how I work now :
- I have to work on a 2000 strategy (strategy A).
- I take a good definition around 2000 too (strategy B) to create a S6x file if not existing (from TunerPro format + SAD DIR files (for registers) + SAD CMT files)
- I open SAD806x on strategy A and compare it with 'Compare Binaries' option with Strategy B. If strategies are really near, result is excellent.
- I export generated report.
- I get all similar items.
- I analyse on a text editor the report to look at all identical routines and get all remaining items.
Pym
Hacker
Unread postby motorhead1991 » Tue Jun 04, 2019 1:36 am
Pym wrote:Some examples for new features in version 1.3 :
Are you going to join us in the OpenEEEC chat yet? :grin: I keep trying to get TVR in there as well.
motorhead1991
Vehicle 2 Information: Stock 1990 Ranger. ICM relocation, Volvo 31lb Bosch injectors, custom tune, e85: 82hp/103tq
Unread postby Pym » Tue Jun 04, 2019 11:51 am
It could be, but for now better than words ...
Do not forget the new included dll.
Pym
Hacker
Unread postby decipha » Tue Jun 04, 2019 12:42 pm
excellent she seems to be running nicely, i ran cdan4 through it and rzasa with no problems
i didnt check but does the exported xdf put the memory addressing in order?
I take it patches aren't copied over from imported xdf's to exported xdf's correct?
Unread postby rocks08 » Tue Jun 04, 2019 1:19 pm
OMG :shock:
This version is awesome. you have make lot of works for the comparison :shock:
i will play a long time with it :mrgreen:
rocks08
Vehicle Information: ford puma 1.7 eecv DUDE
Unread postby Pym » Tue Jun 04, 2019 11:46 pm
decipha wrote:i didnt check but does the exported xdf put the memory addressing in order?
Nothing has really changed for this part.
When creating a new Xdf, XdfUniqueId for item is created ordered by address.
When updating an existing Xdf, XdfUniqueId are kept, so nothing is reordered and patches stays in place too.
Pym
Hacker
Unread postby wwhite » Tue Jun 25, 2019 1:45 pm
Using SAD806x 1.3 20190603, on Linux with wine, trying to change the command options, does not appear to work.
I want to go completely manual, using only directive file.
I put the following at the top of the directive file:
----- Commands ------
opts : C M
bank 00000 0dfff 8
In the output listing file, always has
Options :
Default options
Is the command options not working correctly in this version, or is it an oddity with wine?
Also, cannot get the comments file to work correctly(import .cmt)
Vehicle Information: 1994 Ford F150, SD KID1, TunerPro-RT, QH
351w, long tubes, eddy 3881, XE258HR-12
Vehicle 2 Information: 1964 M100 460, short box
Vehicle 3 Information: 1964 Meteor 390, 2dr, breezeway
Additional Vehicles: 1978 Alfa GTV spica
1978 Alfa spider
Unread postby decipha » Tue Jun 25, 2019 3:54 pm
i coulsnt get it to work wither using a 256k 2 bank file it wouldnt let me
Unread postby Pym » Wed Jun 26, 2019 2:57 am
wwhite wrote:Using SAD806x 1.3 20190603, on Linux with wine, trying to change the command options, does not appear to work.
opts : C M
bank 00000 0dfff 8
Options :
Default options
No way to use a fully manual disassembly mode with SAD806x.
SAD directive opts : C M or bank 00000 0dfff 8 are always ignored.
SAD .dir file import permits to import elements, routines or operations, but nothing else.
SAD .dir file export tries to generate a fully usable .dir file, by recreating a defaulted structure,
but it has to be reviewed manually to match what is really expected.
SAD .cmt files have to be imported after .dir import of after SAD806x first disassembly.
They should match with an already known address, otherwise they will fall into "'Other Addresses".
SAD .cmt files could also generate format issues, I have not seen so much and mines work fine, have you an example ?
Pym
Hacker
Unread postby Pym » Wed Jun 26, 2019 2:58 am
decipha wrote:i coulsnt get it to work wither using a 256k 2 bank file it wouldnt let me
Could you please send me this file ?
Pym
Hacker
Unread postby wwhite » Tue Jul 02, 2019 1:07 pm
Pym wrote:SAD .cmt files could also generate format issues, I have not seen so much and mines work fine, have you an example ?
I am trying to add simple comments, here is an example:
.txt file has:
Bnk8Start:
8 2000: ff        ff
8 2001: fa       di        disable ints;
.dir file has:
sym 2000 8 "Bnk8Start"
sym 2032 8 "Sub00002"
.cmt file has:
2001 # My Comment, disable interrupts.
I am not sure if my .cmt formatting is correct, or if order of import->disassemble->output is correct?
1978 Alfa spider
Unread postby decipha » Tue Jul 02, 2019 3:38 pm
i thought it had to be tank before address no spaces
sym 82032 "subr_blahblah"
Unread postby Pym » Thu Jul 04, 2019 8:30 am
decipha wrote:i thought it had to be tank before address no spaces
For .dir file, format is ok like described in SAD documentation.
Same thing for .cmt file,
but comments are never managed coming from .cmt file for operations, so this comment is probably created in Other part.
Order is fine, the main one to respect is .dir, then .cmt.
Pym
Hacker
Unread postby decipha » Fri Jul 05, 2019 7:15 pm
attached
Unread postby Pym » Sat Jul 06, 2019 3:49 pm
attached
I see not particular issue with last delivered SAD806x version 1.3.
One error is detected on disassembly, but without any consequence.
Have you more details on you issue ?
I attach a print screen (some differences visible on the version, 1.3a, I will deliver it soon, but same result on 1.3).
Pym
Hacker
Unread postby Pym » Fri Jul 12, 2019 4:10 am
A new version of the tool is linked.
I call it 1.3a with a release date set for today (for history purpose).
I always use this one, but I have not tested all updates.
It is an interesting version for many reasons:
- Duplicated elements (Tables, Functions, Scalars and structures) are managed inside tool and with TunerPro Import/Export.
Same address, but different scaling, versioning for history, ...
Only the main element is processed in disassembly output, so new options in menu are added to create / switch from main.
- Update on Import/Export Copy/Paste with TunerPro.
First thing, Copy Xdf and then paste into TunerPro works now. There was an issue with encoding, TunerPro accepts only ANSI for paste input (no UTF-8 or Unicode).
So special characters can cause bad result.
Second Thing, Export Xdf was managed as UTF-8 export too, be understood as ANSI by TunerPro, with issues on special characters.
In this case it works with Unicode, so Export is now done through unicode.
Michael, you talk me about ordering in Xdf files, it was working the first time only when you were exporting.
I have now added a button to reset XdfUniqueId in S6x file. It permit to create a new Xdf file well sorted, even after a first export.
Short Label / Label management has been reviewed between both software.
Import in SAD806x will look at TunerPro Label, then at TunerPro description to search something like xxxx - yyyyyy.
xxxx will become the short label and yyyyyy the label.
For Export short label is forced at the beginning of the comment, if not at this place, to be set in TunerPro description. xxxx - comment.
So my advice is to use Short Label only at the beginning of the comment in TunerPro and in SAD806x.
Last thing is on BitFlags import, which is not managed anymore as a bitflag, when only B0 is set.
It is far more easy to use (for label and short labels) when scalars are switches.
- Scalers on tables have been review too.
First to manage duplicated functions (which is really interesting).
Secondly to be able to display details in a tooltip, when mouse is on the related button,
really useful when working on EECV with many, many scalers.
Finally to be able to search them.
- Data Scaling on tables, directly visible in SAD806x.
Just for fun, but finally useful to quickly identify some scalers or tables.
- Repository management - "Ctrl R".
You have identified a table, a function, a structure, a scalar or a register, but you do not want to write its short label, label or comment.
If you have the perfect repository, just use Ctrl R keys, when you are in a text field and you will be able to search your identified item in the related repository.
Then by selecting it it will fill in for you short label, label or comment.
If you do it on Units fields, you will search for Units from repository and fill in this field.
If you do it on Scale fields, you will search for a scaling from repository and fill in this field.
If you right click on shown data, you will be able to test additional scaling from repository.
But you will have to create your own repository, in fact Xml files in the SAD806x folder.
You can create, update them and mass load them from S6x, from ? menu.
I just provide a basic conversion.xml file to begin.
If you are having issues when saving them, just put SAD806x folder in another place or start it as administrator.
You can after that create dedicated files, because for example EEC IV is not as complete as EEC, but SAD806x will only load one version.
If you want to share them or to translate them, it will be appreciated.
- Mustang 86 VP1 (and sisters) is now well managed too.
A issue was existing with RBase detection on it, but I had not searched for pre GUFX strategies before, so...
By the way, if you know a well disassembled strategy (good names an descriptions), pre GUFX,
100% based on Open loop, it will be interested for my work on European strategies,
which have switched from a pre GUFX strategy (100% Open loop, but not VP1 or LUX0)
to the same core than CBAZA, but in 1992 / 1993, when Closed loop was required.
Pym
Hacker
Unread postby motorhead1991 » Sat Jul 13, 2019 3:43 pm
How would I go about reassigning a function/structure that 806x established? I'm working on an EEC-V binary but the MAF curve is not identified as a function.
Also, being able to load an XDF template for category organizing would be awesome.
motorhead1991
Unread postby Pym » Sun Jul 14, 2019 3:54 pm
motorhead1991 wrote:How would I go about reassigning a function/structure that 806x established? I'm working on an EEC-V binary but the MAF curve is not identified as a function.
For reassigning MAF Transfer that was detected as structure, juste create a new function at the same address (Word/Word with 1 row at least, 30 rows for MAF Transfer).
It will ask you to overwrite the structure. You can also remove the structure and create a basic function at the same address (word/word 1 row at least) and disassemble another time.
For TunerPro categories, it could be an idea, but I am never working with them.
By the way I could surely do something .
Pym
Hacker
Unread postby jsa » Tue Jul 16, 2019 12:51 am
Thanks for the update Pym.
Cheers
John
Power Poster
EEC-IV GHAJ0
SMD-490, SMD-190
Unread postby Pym » Fri Aug 23, 2019 3:53 am
Just detected an issue when using last update on Windows 10 (Windows 10.0.17763 (1809)).
Software can freeze when trying to output an item (when previous item was having comments with carrier returns and with the same thing on new item).
I use a temporary version to continue working, waiting Microsoft to correct the issue. Just tell me if you need it.
Pym
Hacker
Unread postby Pym » Fri Nov 08, 2019 8:13 am
I still call it 1.3a with a release date set for today (for history purpose).
This is the most stable version, which I am using each time.
No new functionality (I think), but many small corrections, for accuracy, speed and so on.
The main thing, is its documentation, which is not in the archive, for size reason.
If you put the pdf file, in the SAD806x folder, you can open it from the tool.
Sources will follow quickly.
Pym
Hacker
Unread postby decipha » Fri Nov 08, 2019 9:14 am
very nice i will tinker with it
Unread postby jsa » Fri Nov 08, 2019 3:26 pm
Good stuff, thanks Pym.
Cheers
John
Power Poster
EEC-IV GHAJ0
SMD-490, SMD-190
Unread postby wwhite » Mon Nov 11, 2019 7:47 pm
Love the PDF document!
1978 Alfa spider
Unread postby Pym » Tue Nov 12, 2019 2:57 am
wwhite wrote:Love the PDF document!
Yes it was more than necessary, I was adding more and more things in the tool and no one was knowing exactly what it was, even me sometimes.
And now, please find attached the related sources, still based on visual studio 2008.
Pym
Hacker
Unread postby motorhead1991 » Tue Nov 12, 2019 1:40 pm
Mind if I create a GitHub repository for it?
motorhead1991
Unread postby jsa » Tue Nov 12, 2019 2:02 pm
Pym wrote:Yes it was more than necessary, I was adding more and more things in the tool and no one was knowing exactly what it was, even me sometimes.
Thanks, the PDF is a big help.
Cheers
John
Power Poster
EEC-IV GHAJ0
SMD-490, SMD-190
Unread postby Pym » Tue Nov 12, 2019 2:17 pm
motorhead1991 wrote:Mind if I create a GitHub repository for it?
No issue on my side, you can do it, it could be very interesting.
Pym
Hacker
Unread postby motorhead1991 » Thu Dec 12, 2019 1:51 am
Alright, you're up and going. I don't have a valid email address for you so I left that bit out. Next, one of us needs to write up a "Readme" file that explains the project and potentially how to build it.
OpenEEC SAD806x
motorhead1991
Unread postby Pym » Sun Dec 15, 2019 4:08 am
motorhead1991 wrote:Alright, you're up and going. I don't have a valid email address for you so I left that bit out. Next, one of us needs to write up a "Readme" file that explains the project and potentially how to build it.
OpenEEC SAD806x
Thank you, I will send you a message on GitHub to get access to the project.
New version can go there and a compiled version, including documentation will be useful.
Pym
Hacker
Unread postby Pym » Tue Feb 18, 2020 5:08 am
OpenEEC SAD806x
I am still not able to do anything with this repository. Just tell me what will be the next step.
Anyway, I have released a new version.
No real big changes and this is why I have not updated previous provided documentation.
- Many small issues were corrected.
- A 'Recent files' menu has been added, for main files.
Yes it was asked for that, from the beginning, but I did not want to use registry, ini files or something in the exe directory.
With the repository, things had changed, so... Generated in the exe directory, so be sure to have the rights.
- A 'Settings/Text Output...' menu has been added in the tools menus.
Same principle, than for 'Recent files', generated in the exe directory, so be sure to have the rights.
By default 'Activate Settings' is not checked, disassembly text output is the same than for 1.3a version.
When 'Activate Settings' is checked, disassembly text output is generated in a different way with default values (not so different).
Then you can update some values (width, labels) to match your expectations.
- Scale precision option is now added for all scale expressions.
It is visible in tool and in text output.
It is also mapped with Xdf format (Import/Export/Copy/Paste)
- Tool screen has a bit changed, it is wider, because of new fields.
Data output has a bit changed too, for performance and for being easier to read.
- A 'Mass Update' menu has been added in tools menu.
For now one option in it, to give a specific format for comments, on the first line.
Useful for Xdf import Export and to have the same format between definitions.
Version is 1.3b with date 2020-02-18. Sources are provided too.
conversion.xml file is default one. Just backup yours before, if required.
Sources have been reuploaded on 19th of February, previous ones were the old ones.
Pym
Hacker
PreviousNext
cron
