Directives file for A1C
Something you are willing to share? Purely for educational purposes.
Re: Directives file for A1C
What are you looking for that is not in the xdf file?
My directive file is just syms for the parameters and a few bits labelled. I don't have any of the subroutines named or anything. As wwhite said theres nothing more other than whats in the xdf.
It was just to have a cleaner look at the subroutines when disassembling the bin.
I see. Yeah I dont have any of the subroutines named
I'm working on a different definition, out of 368 subroutines, I've labeled 258, only 110 to go.
Its' a lot of work:
"Reset_All"
"Initialize"
"Background_Loop"
"Reset_RAM_ptr"
"Infinite_Loop_DEAD"
"Set_TaskList"
"SYSTEM_EQUATIONS_1"
"BRAKE_INPUT"
"Clear_Cell"
"I_External_Vector"
"DCL_Mode_Scheduler"
"DCL_DM_PermanentDeviceDisconnect"
"DCL_DM_TransmitPID"
"DCL_DM_ParameterRefByAddressOffset"
"DCL_DM_ParameterRefByName"
"DCL_DM_A-D_SensorValueSubstitution"
"DCL_DM_ClearContinuousVIPCodes"
"DCL_DM_ClearDCLErrorFlags"
"DCL_DM_TransmitDMRMap"
"DCL_DM_TransmitPIDMap"
"DCL_DM_TransmitDMR"
"DCL_DM_ProgramDataDownload"
"DCL_DM_ProgramExecution"
"DCL_DM_DisplayDCLStatusInformation"
"DCL_DM_RunningOnDemand_SelfTest"
"DCL_DM_TransmitContinuous_SelfTestCodes"
"DCL_DM_SetCommLinkBAUDRate"
"DCL_DM_TransmitBoth_PID-DMR"
"Send_HSO_Cmd"
"Reschedule_Event"
"I_HSI_0"
"Read_HSI"
"I_HSO_1"
"I_Timer_OVF"
"I_Ignore"
"I_HSO_2"
"PIP_DATA"
"SPARK_RETARD_LOGIC"
"SPOUT_CALCULATION"
"Update_HTime_pend"
"Update_HTime_prev"
"KNOCK_THRESHOLD_SENSE_(KTS)_LOGIC"
"Add_H_Beta"
"Add_H_Delta"
"EOS_KAY_CALCULATIONS"
"TRANSIENT_SPARK-COMPENSATION"
"DWELL_CALCULATION"
"FUEL_INJ_OUT_COM6"
"SET_UP_INJECTOR_OUTPUT_EDGE"
"Injector_Edge"
"Injector_Edge_Immediate_Output_Request"
"SCAP_Sensor_Edge"
"SYSEQ_MAP_COM1"
"Calculate_MAP_FREQ"
"MAP_Average_Complete"
"MAP_CALC"
"VEHICLE_SPEED_(VS)"
"VIP_THROTTLE_MODE_SET"
"KAM_Qualification_Test_Logic"
"ReInitialize_ISCKAM"
"RUN_MODE_SELECTION"
"THROTTLE_MODE_SELECTION"
"Read_AD"
"Enable_Int"
"SYSTEM_EQUATIONS_EQUA_LH"
"INPUT_ACT_COM2"
"Compute_TCSTRT"
"INPUT_TOT_COM1"
"CNVRT"
"ENGINE_SPEED_OVER_VEHICLE_SPEED_NOVS_&_BPCOR"
"INTRN_MLPS_CONV_COM1"
"INFERRED_BAROMETRIC_PRESSURE_STRATEGY"
"SPEED_DENSITY_AIR_MASS_CALCULATION"
"Compute_AMPEM_AMPEMT"
"Subtract_EM"
"AD_Substitutions"
"DCL_Handler_Dispatch"
"BIMAP_DEFINITIONS"
"DOL_PULSE_CALC_COM3"
"SUYFuncLU_4865"
"USYFuncLU_486d"
"UUYFuncLU_4870"
"UUYFuncLU_4891"
"SUWFuncLU_48db"
"SSWFuncLU_48e0"  $ F sswflu 32
"USWFuncLU_48e3"  $ F uswflu 32
"UUWFuncLU_48e6"
"UUWFuncLU_4907"
"UROLAV"
"ROLAV"
"ROLLING_AVERAGE_ROUTINE"
"ROLLING_AVERAGE_FILTER_ROUTINE"
"SYTabLU_49a7"  $ F sytlu 38 34
"SYTabLU_49b6"  $ F sytlu 38 34
"Four_Point_Interpolation" $ F uytlu 38 34
"TableInterpolation"
"Calculation_Normalized_MAP"
"Calculation_MAPWBAR"
"FUEL_OLFLG_COM7"
"TIMERS"
"FUEL_CL_LAMBSE_COM3"
"C_MULTIPLIER_LOGIC"
"LAMBSE_RESET"
"ACT_to_ECT_proportioning_factor(R36)"
"FN1360(N,MAPPA)"
"TEMP_normalization_factor_x"
"CALCULATE_PTPAMP_RF_and_RS"
"UYTabLU_5131"  $ F uytlu 38 34
"FUEL_ADAPT_COM4"
"EGO_Switch_Logic"
"NEW_UPRATE_CALC"
"FUEL_IDLE_MOD_COM3"
"FUEL_KAM_ADAPT_COM3"
"FUEL_TRANS_COM5"
"FUEL_DFSO_COM2"
"FUEL_AE_COM5"
"FUEL_PUMP_COM1"
"SPARK_BASE_COM2"
"Include_in_SPK_NORM"
"ENTRY_INTO_IDLE_SPARK"
"MISCELLANEOUS_SPARK_CALCULATIONS"
"DWLBSE-DWLCOR_CALCULATION"
"SPKKNOCK_LL"
"KNOCK_HARDWARE_PRESENT"
"EGR_ENABLE_LH"
"EGR_SONIC_COM2"
"DESEM_DELOPT_CALC"
"EGRDC_CALC"
"EGR_EVR_CONTROL_COM1"
"ISC_OVERVIEW_COM3"
"DSDRPM_CALC"
"RPMERR_CALC"
"ISC_DASPOT_COM1"
"ISC_MODE_SELECT_COM1"
"ISC_IPSIBR_COM1"
"ISC_ISCDTY_COM1"
"Manifold_VACUUM"
"ISC_ISCKAM_COM1"
"DOL_LH"
"ACC_GOV_MAP_COM2"
"THERMACTOR_AIR_STRATEGY"
"CANP_COM4"
"Update_Can_Purge"
"Do_Self_Test"
"StackErrorCodes"
"Get_DiagCodes"
"Set_DiagCodes"
"EGR_SELECT_LOGIC"
"TRANS_SELECT_LOGIC"
"Check_Sensors"
"EGOTST_TMR_CONTROL"
"WARM_UP_COUNTER_LOGIC"
"KAM_CODE_ERASE_LOGIC"
"?Fault_Filter_Routine?"
"Clear_KAM"
"Clear_Kam_SelfTest"
"Set_STO"
"Reset_STO"
"GetBytes_R1a"
"EGO_TEST_TMR_CLEAR"
"Calculate_ETV_OCM_MIN"
"VO_EOTS_COM1"
"FAIL_Loop"
"VO_ROM_COM1"
"TEST_AD_SWITCHES_1"
"EXIT_THIS_TEST"
"TEST_AD_SWITCHES_2"
"GET_ADDRESS"
"VO_FPM_COM2"
"VO_OCC_COM12_Func1"
"VO_OCC_COM12_Func2"
"VO_OCC_COM12_Func4"
"VO_EPC_SOLENOID_COM1"
"Disable_No_Start"
"VO_KAMRAM_COM1"
"RAM_ERROR"
"VO_EPC_SOLENOID_COM1_624"
"VO_EPC_SOLENOID_COM1_625"
"SET_SERVICE_CODE"
"VR_RUN_INIT_COM8"
"FMEM_FAULT_PRESENT_and_INITIALATION_LOGIC"
"VR_EGO_COM1"
"VR_THERMAIR_COM2"
"AIR_UPSTREAM"
"AIR_DOWNSTREAM"
"BLOCK_F2_VR_THERMAIR_COM2"
"AM1_AM2_OFF"
"BLOCK_AA"
"DELAY_SEC"
"VR_SPARK_COM1_SAF"
"VR_SPARK_COM1_NBAR"
"VR_SPARK_COM1_213"
"DELAY_SEC(VSPTD)"
"VR_EGR_COM6"
"VR_EGR_COM6_332"
"EXIT"
"VR_LOW_ISC_COM4"
"VR_LOW_ISC_COM4_411"
"VR_GOOSE_SD_COM1"
"VR_GOOSE_SD_COM1_SET_CODE_xxx"
"VR_GOOSE_SD_COM1_G1"
"Check_PS_PB"
"VR_EGOBAR_COM1"
"HW_Check"
"POP_test"
"ZERO_MILTMR"
"VIP_EOS_IDM"
"E4OD_TRANSMISSION_CALCULATIONS"
"INTRN_E4OD_INPUT_PROCESSING_COM1"
"INTRN_E4OD_SYS_EQU_COM1"
"SPEED_RATIO_ACROSS_TORQUE_CONVERTER"
"E4OD_INPUT_PROCESSING_COM1"
"FN161x(N,LOAD)"
"SC_DESRD_GR_DETR_COM1"
"SC_GR_DS_AUTO_COM1"
"VEHICLE_SPEED_SENSOR_OK_SHIFT_LOGIC"
"VEHICLE_SPEED_SENSOR_FAILURE_SHIFT_LOGIC"
"Delay_Shift_Logic"
"MANUAL_DOWNSHIFT_DETERMINATION"
"SC_CM_GR_DETR_COM1"
"SC_CM_GR_MAN1_COM1"
"SC_CM_GR_MAN2_COM1"
"SC_CM_GR_AUTO_DWN_COM1"
"SC_TIMER_COM1"
"SC_SOL_CTL_COM1"
"SC_VALID_COM1"
"SHIFT_VERIFICATION_LOGIC_(Part_1)"
"SHIFT_VERIFICATION_LOGIC_(Part_2)"
"CCC_CST_CLTCH_CTL_COM1"
"EPC_GUIDE_COM1"
"UUWFuncLU_98a7"
"SUWFuncLU_98ae"
"EPC_TQ_IALPHA_COM4"
"EPC_DYNAMIC_COM1"
"CCC_COM1"
"CCC_FMEM_COM2"
"CCC_UNCOND_UNLCK_COM1"
"CCC_SHFT_UNLCK_COM1"
"CCC_INI_DWN_COM1"
"CCC_DWN_CNVR_CLCH_COM1"
"CCC_INI_UP_COM1"
"Calc_SR_PP_LIM"
"CCC_UP_CNVR_CLCH_COM2"
"CCC_SCHLD_LCK_UNLCK_COM1"
"CCC_WOT_LCK_UP_COM1"
"INTRN_RT_NOVS_KAM_CALC_COM1"
"CCC_VALID_COM2"
"INTRN_TCIL_REPEAT_COM1"
"EPC_OTEMP_TEST_COM2"
"TIMER_LH"
"Check_ConsoleDI"
"Check_Console"
"Console_Routine"
"KAM_VALIDATION_PROCEDURE"
ironmanisanemic
Vehicle Information: 1989 Ford Bronco
U4P0 Processor
393w Stroker, 4R70W
Unread post by ironmanisanemic »
I am also looking for directives to study. Ive been trying to learn how to do this, but not having any programming experience, I have a hard time understanding what each subroutine is actually trying to do. Having a few of these to look at and compare to the one I am trying to work on could help me (and probably most other people learning) understand what and how these work. Could lead to a larger pool of signature based identification in things like SAD.
I know most people that can and do disassembly and strategy development, dont want to give away their hard work. So thats usually why i havent seen much in the way of this kind of information. This is a shame though, as the community could go alot further to having more free defs, and possibly more people to help in developing strategies.
In order to understand the code and functions you need to read and understand the strategy documentation, the ones with 1200 pages. Those describe the functions perfectly, well in fords standards.
Just looking at code probably won’t get you far if you are not a programmer.
Jamie from oz
Is there a strategy document (1200 page) avalable to download?
I am trying to work out sub routes on a Australia 6tac so I can get a payload made to datalog.
Also going to change it from inline 6 cyl SD to v8 SD so I can have our Australian 4 speed BTR auto tunable with quaterhorse. (have found the injector port/numbers but have not loaded it to try it yet)
Wwhite is referring to the publicly available ones which can be found at
https://github.com/OpenEEC-Project/Strategy-Documents
