A9L2 uses a stoich AFR setting of 14.079:1. Where I fill up, the premium fuel is labelled "NO ethanol". Do you think that's a valid enough reason for me to change my stoich AFR to 14.64:1? Any precautions I should be aware of?
Sean
changing stoich AFR to 14.64?
Re: changing stoich AFR to 14.64?
yep you should always put the most accurate info in your tune
go ahead and change it no prob
