Driving aftermarket tach with eecV
Unread postby Mnorman1964 » Tue Nov 05, 2019 2:20 pm
I have an eecv 2000 model with an rpm out pin that's not being used. Does anyone know if that is compatible to drive an aftermarket tach?
Mnorman1964
Premium Member
Vehicle Information: 1969 F100 Truck SWB
5.4 2002 32V DOHC engine from Navigator
4r100 trans
MQAIO EECV stock
10:1 comp
Stock Cams
Stock injectors
Long tube headers
Stock MAF
Stock Heads
80mm aftermarket throttle body with stock TPS
Boss Coyote Intake with custom adapter plates
Return type fuel system with high volume EFI pump
Vehicle 2 Information: 2003 F150 FX4
5.4L stock everything
Quarterhorse with TunerproRT
Re: Driving aftermarket tach with eecV
Unread postby decipha » Tue Nov 05, 2019 5:10 pm
if its not used it prob doesn't have the tach output hardware present
in any case im not sure it would be the same signal the aftermarket tach is looking for
Name: Michael Decipha Ponto
06 Chrysler 300 AWD - Sharifa
Unread postby 034v » Wed Nov 06, 2019 7:28 am
try a MSD tach driver
Created the TPRT XDF's below in my spare time. More to come as time allows. Let me know if you need one.
1996 Lincoln Mark VIII CDBA4
96-97 Ford Car CDAN4
97-98 Lincoln Mark VIII CMBA0/CMAI3/6/7/9
93-95 Lincoln Mark VIII CZAJL
87-92 Lincoln Mark VII SFI-SD3
034v
Vehicle Information: 1996 Lincoln Mark VIII, TPRT Tuning with my own XDF
Vehicle 2 Information: 1994 Lincoln Mark VIII, TPRT Tuned with my own XDF
Vehicle 3 Information: 2009 Ford F150, Work Horse, SCT Tuned by me
Unread postby jsa » Fri Nov 08, 2019 4:44 pm
You would need to ask the tach manufacturer if their product supported the eec tach signal.
You would be wise to put a multimeter on that tach pin to check for a signal.
Another interface solution.
https://www.diyautotune.com/product/axm ... 0b2dce18c9
Cheers
John
EEC-IV GHAJ0
ANTI, COSY, QUIK or CARD
SMD-490, SMD-190
Unread postby Mnorman1964 » Mon Jan 27, 2020 11:33 am
Found a cheap solution that works. This guy took real good care of me and matched me up to the right part. Hooks up to one of my cop coil feed wires. Cost less than $40
https://www.ebay.com/itm/COP-DIS-TACH-ADAPTER-convert-COP-or-DIS-pack-ignition-to-any-4-8-cyl-Tach/142495590237?hash=item212d66275d:g:clwAAOSwkERb~MSA
Mnorman1964
Premium Member
4r100 trans
MQAIO EECV stock
10:1 comp
Stock Cams
Stock injectors
Long tube headers
Stock MAF
Stock Heads
Return to General Hardware
