LHBL0 -- 94 Lightning
Remanned ECU..
Yanked the BIN and came up with this.
The offset is off vs. the SD4x stuff on the homepage, so I ran it thru SAD and compiled a small 160 ish something XDF. However it's missing a few goodies I cannot find.
LMK
LMK
- LHBL0-READ.bin
- (56 KiB) Downloaded 273 times
Re: LHBL0 -- 94 Lightning
I'd say you have a 1996 or newer strategy.
Latest and greatest stock ford code you have there for 5.8l w/E4OD.
I think it is identical to LAD1.
No definition exists publicly that I know of.The offset is off vs. the SD4x stuff on the homepage
Double check the strategy with the ALT0 cal. It may be one of the cals that share that strategy.
I looked at the injector slope and thats not for a lightning its for a 351w non lightning.
Yeah its identical to LAD1 except for some minor transmission adjustments.
Yea shows A0 at like 18 lbs/hr
From what I've gathered on the minor disassembly I've done, it's a work truck non GT40 351 ECU.
Looks like calibration data is in the same location as ALT0.
Isn't ALT0 for 460ci?
Is there an adx/xdf for ALT0 on efidynotuning?
I
I
Yes, it is the ALT0 binary. It is the 1995 CAL and all set for the 7.5L.
I have created 2 XDF's. One for the remanufactured offset and one for the -2000. They both work.
Now I'm creating a base Lightning tune to start from so this guy can get his truck running right. Once done, I'll dial-in all the stuff he needs.
No wonder his truck was a turd. 3600 WOT 12 shift and VE stuff all wrong.
why go through all that trouble when you can just use a1c ?
A1C didn't line up. The ecu I read has an offset at 8192/2000.
Nothing I had would line up at all. The binary I posted, I removed the first 8192 byte from it.
I didn't think burning the chip starting at 0 would work if the structure is starting at 2000.
You thought wrong.
But it didn't.
A1C_200702 from here does not show meaningful stuff when using this binary. Literally 2177 byte off from each other with where anything is that is considered tuneable.
So, I made two versions of my own that works with this particular BIN, for this particular truck.
Now, if I take the LHBL0 with the padded first 8192 byte (which is what the ECU has spit out), it will not load with other tuning software I have. If I take the first 8192 out, it works. Since my customer doesn't use the software, and he in no way will be able to convert your A1C himself, I took it out of the equation and made 2 versions for him that he can use.
Make sense?
Make sense?
