92 fox body 347 CID running #30 injectors. I am using Tuner pro...
I'm going to switch my tune over to E85 fuel, I have a set of #42 injectors left over from my Lightning.
My question can I use one of the Injector Flow Data from your web site? If so which one? Or which injectors do you recommend I use for my combo?
Thank you
MB
Flow data for 42s
Re: Flow data for 42s
the f302 data for 55psi
- Vehicle Information: Ford 1992 LX vert AM3 342 CID TFS heads 10.1 CR Long Tubes Holley Systemax Intake Accufab 75mm TB #30 INJ T5 trans 3.73 gears 150 shot NOS
Thank you :)
