Late 1-2 shift intermittently 4R70W
m-barans
Unread post by m-barans »
So sometimes my 1-2 shift is so retarded/delayed that the rev limiter is hit and the car stops accelerating of course until the shift is made. My first thought was the main control/ valve body but now I’m thinking it’s maybe a broken 1/2 accumulator spring or something. What to check? Should I buy the violet and light blue springs for the 1/2 accumulator? The trans only has 60k on it currently. I’d like to have minimal down time. Can I yank a newer 4R75 valve body from a yard and potentially use that if needed? Im not looking for anything super aggressive shift kit wise but open to suggestions for my 03 marauder trans. Thanks
Re: Late 1-2 shift intermittently 4R70W
the 1-2 shift can be made as firm as you want in stock form no problem.
Go kick up the 1-2 tv pressure table
Blocmi
Unread post by Blocmi »
Did you change rear gears?
Many people run into this problem when going to a higher rear gear ratio. I suppose it could happen with more power as well...
It's all about clutch fill time vs how fast your rpm is climbing.
IIRC there are a couple options to remedy.
1. Command the shift at a lower rpm so the clutch has more time to fill...
2. Enlarge a hole in the valve body separator plate to allow the intermediate clutch to fill more quickly.
Keep in mind, the 1-2 factory aluminum accumulator is known to wear out quickly on early transmissions, if yours is a 2003, it may have the bonded rubber already. If you're pulling the pan, it can be checked and or replaced with a bonded rubber replacement without dropping anything else.
I found the TCCoa forums (Thunderbird car club) has a wealth of information on AODE/4R70w mechanical function, issues, troubleshooting, rebuilding, and modifying. https://www.tccoa.com/forums/automatic- ... sions.990/
No need in doing any of that just simply kick up the 1-2 as stated in the previous post
m-barans
Blocmi wrote: 2021 Jul 02, 10:25 Did you change rear gears?
Thanks for the information. I always appreciated the Supercoupe guys since my first one (95 auto SC) I purchased a 90 5 speed SC which was even more fun but those cars got me hooked on PD blower boost! I’m going to work on tuning the electronic control end before I drop the pan. I’d like to avoid mechanically altering the trans/ shift kit
m-barans
decipha wrote: 2021 Jul 03, 20:35 No need in doing any of that just simply kick up the 1-2 as stated in the previous post
So I believe I found the TV pressure 1-2 shift table. Looks like output is PSI. I’m guessing I should add maybe 5 in the areas with higher TP rel. Maybe blend that in the table so it still ramps nicely? I will give that a try and see how it improves and report back. Thanks
034v
Unread post by 034v »
In the TV tables, 650+ TP make 99.
Max TV scalars are around 95
No less than 10 so you don't get drop-out
No, absolutely do not do that as it will bang so hard you'll eventually destroy the transmission and or break stuff.
Most marauders I put the 1-2 shift pressure at around 30 psi. If its boosted you can kick it up in the 40s. Much more than that and you'll need an MRI and a neck brace if you manage to keep traction.
034v
decipha wrote: 2021 Jul 07, 15:46 No, absolutely do not do that as it will bang so hard you'll eventually destroy the transmission and or break stuff.
Ah.. nevermind lol. Not on them. didn't fully read it was a Marauder. my bad.
I was thinking Mark VIII without a Jmod.
m-barans
Ok, thanks for the information. I made some changes to the 1-2 shift but not really finding the results so I will investigate the mechanics of it after I get the car running again. The 03 cobra eaton needs a freshening up (noisy rotor pack) so she is disabled for the time being. Updates to come
