Luxury ECU wiring questions
Re: Luxury ECU wiring questions
your not gonna use any of those
yep u can add a knock sensor
aod is probably a hall but u can wire it up to the oss and we can see if it works
- Vehicle Information: 1991 Ford Mustang GT
A9L - BE/EA
Are you running all ground pins # 3,24,25,51,76 and 103 to a single point on the chassis?
yep dont forget 77
Any problems with eliminating the downstream Hegos? Hego 12/22. Also, my ECU harness does not have pin 77 as an open connection, its capped off. I got the ecu and harness from the same Crown Vic.
nope just use what you need
Should I run the wiring for OSS and VSS incase I need to change it around or should I not worry about it and just repin it at the ecu if needed? I assume both of them use signal return?
just swap it at the ecu
yep
yep
pin 29 TCS=Overdrive switch? Not sure I need an overdrive switch
