Late 1-2 shift intermittently 4R70W
Re: Late 1-2 shift intermittently 4R70W
Update: I went ahead and replaced the 1-2 shift servi and the springs (which were different than what was in there) per ford (snap on) catalog. So far it hasn’t acted up again. I reduced the speed at which 1-2 is commanded and now currently playing with pressure. Decipha’s recommendation considered I am at 30 psi and probably going to experiment with the next 10. Thanks everyone!
I am running into the rev limiter because the shift doesn’t happen correctly. I don’t seem to be making any progress by changing the tv table. Can somebody confirm what table I should be adjusting by calling it out as in TunerPro please? Also, thinking of doing j-mod as well. Please assist, thank you
marauder valve body already has the 'j-mod' from the factory
there's three things for the shift to occur on time
first make sure the vehicle speed isn't too high, thats in the shift schedule function fn23s if its the 2-3 shift, if the wot tprel speed value is too high then its going to wait until that vehicle speed to make the shift regardless. You can verify by the shift gear commanded at the bottom right of the dashboard.
if its not commanding the shift then its never going to shift
shift pressure is fn23dytx_vs - dynamic epc 2-3 shift
the last two columns should be wot shift pressure. If you kick those up you will command more line pressure during the shift. That could make it shift faster but it will reach a point where it will make it shift harder and not necessarily faster that's when you know you've got too much.
then you have the tcc fill last
fnup2dly is the 2-3 shift tcc fill time, kicked up that value will command the shift sooner.
Post your tune file and a log of this missed shift and i can probably see whats going on exactly from the log.
