A1C XDF Additions
A1C XDF Additions
Thanks to wwhite I am adding some parameters to A1C as needed. Setting the Stoich AFR Scalar to 10:1 helped my e85 tune nicely. Please add to your next revision.
Re: A1C XDF Additions
added will be in next update
Thanks for adding the trans stuff. There appears to be an error with FN1355 on the latest XDF. I believe the correct address is A92E but is set at B5DA in the xdf. It wiped fn32s when I set FN1355 to zero so that's how I found it.
correct i fixed it. thanks
FN23T is at B8D6
thanks
when time permits im going to go through all the auto trans stuff and verify
ok thanks, It looks pretty good now but fn23T was just missing
it was labelled wrong on mine.
