Looking for PYCL4 bin and xdf files
I clicked on EEC MASTER HARDWARE LIST which showed a list of strategies to download. Then I clicked on PCYL4 and it brought me here to this category. I'm wanting a bin and xdf file that will work on my wife's truck.
Re: Looking for PYCL4 bin and xdf files
You have to be a premium member to request files to be created.
Ok. I guess that is why I didn't see it. Do you have enough of a def file to turn off the rear o2 sensors for cats delete? I don't see it as a performance type vehicle that I would need to have a fully blown out def. I could just send you the bin file from it to do it since I now have and know how to use the PCMFlash software with the Scanmatik 2 Pro. PM with what you can do. Some bright individual cut the catalytic converters off before we purchased the truck. Thanks!
Just post the file here no prob
I've spent the last two hours trying to relearn what I learned in early October, running a bin file through SAD. Finally I got it.
I thought I might give it a go trying to find out how to turn of rear o2 sensors. Also, I don't know what I would be looking for as far as the rear o2 sensor/s are concerned. Clearly, I don't know much about what I'm doing. I'm still trying.
Add to your list of quality pass through devices, the Made in Spain Scanmatik 2 Pro device works very well with the PCMFlash software. Is it technically Russian or Kazakhstanian software?
2L2AAC_PYAF246-20231126-183736 11-26-23.bin
(224 KiB) Downloaded 105 times
