Mechanical idle - 1861
Re: Mechanical idle - 1861
just post some updated info in the idle air write up
been 7 years since last updated
entity-unknown
Vehicle Information: 87 Bronco FSB Eddie Bauer w/ 89 Mustang MAF Swap / C3W PCM w/ A9L2 BIN from Decipha / 347 FRPP BOSS Block (Part# M-6009-347) / AFR 165cc heads / 42Lbs Green(Active) & 30Lbs Red(Shelf) Bosch Injectors / CompCams 35-510-8/FW XE258HR-12 / AOD fully beefed up / King 2.5" Suspension w/ Bump Stops / 5.13 Gears Front/Rear on Auburn Pro LSD / 35"(Active)/33"/37" Tires / Very Custom Built Bronco aka Bonnie
Unread post by entity-unknown »
Woohoo! Thank you Decipha! Happy Thanksgiving too!
yep no prob
/enjoy
