[OMAE2] Strategy Files
Can be used on all 2002-2003 harley trucks and lightnings.
EKO2 - 2002-2003 harley and lightning.
Note: EKO1 is the 2002 harley which uses the older strategy OMAE1 instead but is directly swapped out with EKO2. Same goes for the lightning catch codes which can be swapped out with EKO2 just update the gear ratio and tire size.
OMAE2_231113.xdf
OMAE2 def file
(608.87 KiB) Downloaded 176 times
DECIPHA_220505d.adx
OMAE2 selected
(398.31 KiB) Downloaded 356 times
Stock_EKO2_256k.bin
(256 KiB) Downloaded 522 times
Re: [OMAE2] Strategy Files
Attached my stock tune file from my harley truck.
Just added HLODH to prevent power enrichment lambse being commanded on closed loop re-entry which causes an excessive amount of time to return to stoich after exiting wot or when stabbing the throttle.
updated xdf posted
I simplified iac multiplier to target iscdc but theres a n-d air modifier causing iac to 0 out on transitions. Will be adding it with the next update.
new xdf posted with added parameters
Locked
