by decipha » Sat Feb 11, 2017 10:14 pm
Well I just went and picked up the latest addition to the fleet
An 03 Marauder I named Dyshyky (Dye-Shee'-Key)
Bone stock all original and will stay exactly as such
____________________maintenance_________
u joints - june 2018
fan 2018 GT - sept 2018
ac blend door actuator - 10-14-2018
rotated tires, new front hubs, rotors and pads - 11/22/19
blower motor resistor, headlight wiring, grill, belt and tensioner - 01/19/2020
oil changed
04-24-17 34,760
07-31-17 38,580
02-01-18 43,872
02-24-19 53,840
11-02-19 62,571
07-09-20 73,637
by decipha » Sun Jun 10, 2018 11:39 pm
Got a 20k mile all original 03/04 cobra setup complete with blower and all from my friend Chris the owner of the old 49 Performance / Speed Productions out in Jackson / Florence Mississippi.
Will be detuned for 87 octane still but should be a nice little bump in output. Should be around 16psi on stock eaton ~300rwhp or so. About 100 rwhp more than now on 87.
Plan on swapping it in as soon as time allows.
by decipha » Fri Jul 06, 2018 4:33 am
tinted the tails day before yesters
by decipha » Sat Mar 14, 2020 1:26 am
I have her out here in victoria texas and decided to plasti dip the wheels this evening.
<copied from yahoo cached threads> placed here for reference
Deciphas 03 Marauder "Dyshyky"
Re: Deciphas 03 Marauder "Dyshyky"
Hows the marauder working out so far? Ive really thought about parting ways with my mach 1 and getting a marauder. That or an auto Mach 1. Yeah i know im weird for wanting an auto mach over my manual mach.
I started a new job back in 2020. I've driven the marauder maybe twice since then. She's sitting in my backyard right now. I moved her around the other day. No time to tinker. Hopefully in a few years I'll get some free time to swap the engine out.
I didn't realize "Dyshyky" was down. Upgrading the engine?
You missed the OP.
"Got a 20k mile all original 03/04 cobra setup complete with blower and all".
I see now
- Vehicle Information: 1993 Ford Thunderbird SC
3.8L V6
8.8:1 compression
polished SC crank
Ross custom pistons
Eagle rods
dual valve springs
NGK BR7EF plugs gapped @ 0.030
Precision 46mm waste gate
3" exhaust w/ cutout
FMIC
SCT BA5000 MAF
Tial Q 50mm BOV
80lb Siemens Deka injectors
modified F-150 4.2 fuel rail
Walbro 450 pump
8AN feed, 6AN return
wbo2_lc1mtxl
i love Marauders.. one of my dream projects for a long time has been a 6 speed swapped Marauder with boost, probably a single turbo. too bad they didn't quite slip under the radar as far as collector car prices go, which it looked like they might for a while there, lol... still a relative bargain though, whether as a bone stock driver or something a lot more radical. the one that Cleetus McFarland raffled off REALLY blew my skirt up, even though it was autotragic ❤️
