I've been chatting with some people on modular fords forum, about why my blower isn't making boost at low RPM, and they seem pretty concerned I'm going to need a standalone ECU when I hit the 64lb/hr MAF limit.
I'm confident the BAI1 in my car can do everything I need it to with the QH on it, but I'm unclear if I'll need to scale all the SP*** items in the xdf.
Does CRAI8 have decipha defenitions mentioned in the fuel write up built into it? I have the k-constant at 30 and real world values in SARCHG, injector slopes, MAF xfer etc. Will I need to scale all of them if I go to a SCT2800 MAF and 60lb injectors?
Thanks for your help,
Paul
MAF and injector ECU limits
- Vehicle Information: 1998 Ford Mustang GT 5 speed box code BAI1, CRAI8
2008 4.6
PI Heads and Cams
9:1 forged pistons
Forged H-Beam Rods
60lb Deka injectors
BA2800 MAF
- tuning with TunerProRT
PLX Wideband
GM 3bar MAP
Re: MAF and injector ECU limits
as long as the k constant is set to 30 the ecu has no limits.
All good.
Those who speak otherwise about limits are ignorant.
All good.
