A9L2 Base Calibration
Re: A9L2 Base Calibration
Unread postby decipha » Wed Feb 24, 2016 10:26 pm
yep, as long as you know whats really going on theres nothing to worry about
My current a9l2 (not posted) is far beyond what gufb could display to be even remotely correct, thus when i do finish up on my def file for tunerpro ill name it GUFX so theres absolutely no confusion
Name: Michael Decipha Ponto
Unread postby 85GT » Wed Feb 24, 2016 11:49 pm
The guy running it said he only changed injector settings and MAF curve. Yet in his log, the KAMRFs are all 1's which made me think that 258 value i'm seeing was preventing his adaptives.
85GT
Advanced Tuner
Unread postby decipha » Thu Feb 25, 2016 9:19 am
nope
Unread postby JETFAST » Mon Apr 25, 2016 1:28 pm
so i down loaded a9l2 today, and compared it to, what i thought, was a my already current version, and it showed a difference of 82 rows. Would it be safe to say, I need to update and start over?
JETFAST
Vehicle Information: Horsepower Breader
Unread postby decipha » Mon Apr 25, 2016 2:19 pm
I would
Unread postby JETFAST » Mon Apr 25, 2016 2:32 pm
Thank You, for the quick response.
is FN901 base spark table no longer used? All timing is now controlled threw FN904A the sea level spark table?
Does the base spark table need to be populated? does it do anything?
JETFAST
Unread postby decipha » Mon Apr 25, 2016 4:25 pm
sealevel only base is disabled
Unread postby boostup89 » Mon May 02, 2016 9:17 pm
This A9L2 has me curious. I punched in the MAF transfers, injector slopes and offsets (thanks decipha!) My car idles much better, and A/F's are around 14.0-14.5. Can I just download the A9L2 and copy my MAF transfers and injector info to that file? Will It have much benefit? Sorry I'm new to this.
boostup89
Vehicle Information: 89 Mustang GT, 306, afr185's, TFS stage1 cam, 76mm turbo.
Unread postby decipha » Mon May 02, 2016 9:52 pm
yep sure can
benefit.. all the improved decipha code in the a9l2
Unread postby cmlomax » Thu May 26, 2016 4:39 pm
I just re-downloaded A9L2 and loaded it in BE. I got the following errors:
cmlomax
Vehicle Information: 1990 Mustang GT stock bottom end
QH/BE, LMAF, AFM Powerpipe, Accufab 70mm TB, E-brock Performer intake, FMS 24lb injectors, E-brock Performer heads, Crane Cobra 1.7rr's, E303 cam, BBK shorties, BBK catted H-pipe, E-brock RPM mufflers w/ turndowns, T-5 trans, 3.55 gears
Unread postby decipha » Thu May 26, 2016 5:46 pm
thats not an error just BE is unaware of my nitrous code
you can delete that scalar from your BE def file so it doesnt pop up
Unread postby g3mustang » Tue May 31, 2016 10:59 am
when is the nitrous going to be done im still running it off fan
g3mustang
Supporting Member
Vehicle Information: 393 s475 b/w turbo 9:1 compresion 185 afr heads c4 trans a9l2 tunning with BE e85
331 180 heads, cobra intake, 50lb injec., cobra maf, anderson cam
Unread postby decipha » Tue May 31, 2016 12:35 pm
as far as a public release, not anytime soon, for the past few years I've only been offering it on my custom tunes
i do have a 250 shot going on my friends 95 so i'll be rewriting it on cbaza and porting it back over to gufb and fbfg2/rzasa
Unread postby jhine5588 » Tue Mar 28, 2017 3:53 pm
I can not seem to download the A9L2 BIN file. I have a version I downloaded back in August of last year, just wanted to make sure there aren't any "new tricks" that have been worked into the newest version.
Jeremy
P.S. I found the link in another thread...
http://www.efidynotuning.com/cal/A9L2_20161208.zip
I'm looking forward to messing around with this and I can't thank you (decipha) enough for all of this knowledge and ability you've bestowed on all of us wanna-be tooners!!
jhine5588
Vehicle Information: 1983 LTD station wagon: Blueprint 5.0 longblock, TFS springs and intake, B-cam +4 degrees, MAC longtubes, catted H-pipe, Deka 80's, C&L 76mm 230whp/280ftlbs
Unread postby decipha » Wed Mar 29, 2017 2:09 am
is it not on the homepage under base tunes?
Unread postby jhine5588 » Wed Mar 29, 2017 5:29 am
Correct. The link at the bottom of the A9L2 write-up takes you to the home page.
http://efidynotuning.com/index.htm << That's the direct copy link from your hyperlink "Downloads >> TunerPro Files >> A9L2"
Jeremy
jhine5588
Unread postby Bcsader » Tue Apr 04, 2017 6:41 am
Hey Decipha,
I am looking at the FN1861 ISC Startup multiplier table. In the stock A9L it only goes up to 30 seconds after startup but in the A9L2 it continues up to 255 seconds after startup. I want to adjust things because on warm startup the idle hangs high and I want to bring it back down quicker similar to the stock setup. Before I did anything I just wanted to check with you and determine your logic on extending it out so far after startup. Sorry if I should have started a new thread I wasn't sure since this is technically a question about the A9L2.
Thanks,
Brian
Bcsader
Vehicle Information: 1990 Ford Mustang 302, Tremec 3550, 3.73's, Trick Flow Track Heat Heads and Intake, E303 cam, 24# injectors, PRO-M MAF, shorty headers, offroad X, and bassani mufflers. Getting started with moates QH and TunerPro RT.
Unread postby decipha » Tue Apr 04, 2017 11:58 am
the scaling is irrelevant just set the cells to the airflow you want
Unread postby jhine5588 » Sun May 21, 2017 2:27 pm
When dialing in FN035 is everything below 1300 disregarded or does it interpolate from zero RPM?
Jeremy
jhine5588
Unread postby SlowBox » Sun May 21, 2017 4:42 pm
FN035 starts at 0. Obviously you can't dial that in, so Decipha has it set to 200 perload to keep off idle tip in load spikes from commanding ridiculous lambse.
SlowBox
Advanced Tuner
4r70w, 3.73
GT-40P heads
Alex's Parts springs
Stock cam
9.7:1
GT-40 upper and lower
65mm TB
Decapped injectors
Single 70mm snail
U4P0/U4P2/CBAZA
TunerPro v5
Moates QH v1.6
Unread postby jhine5588 » Sun May 21, 2017 5:17 pm
Ridiculous lambse would equal bad AFR's while doing things like slipping the clutch on a hill...
I have a low RPM shutter while lugging the car below 1300. Wasn't sure if that correlated. I assume it's more the MAFv than anything at this point being as all that I have dialed in is PERLOAD and now I'm looking through the fueling and MAF curve.
I have to admit that it appears there's no room for improvement by a novice like myself through seat of the pants "tuning" over the A9L2 base tune. I feel as if I'm almost to the point of putting it on the dyno and see what we can do with the rest. Great job Decipha!!
Jeremy
jhine5588
Unread postby david claflin » Wed May 24, 2017 8:14 am
Is there any issue in running this A9L2 base cal with BE? I get a lot of error messages when I try to run it. The T4M2 worked fine...
david claflin
Vehicle Information: 1990 LX A9L
Vehicle 2 Information: 1985 LTD LX A9P
Vehicle 3 Information: 1986 FHP DB1
Additional Vehicles: 1984 LTD wagon Dugan Wagon A9L
Unread postby decipha » Wed May 24, 2017 2:10 pm
I have a bunch of custom code i wrote in the a9l2 and moving some scaling functions for better resolution, BE doesnt allow dynamic function scaling nor arithmetic on binary values so theres no way to know what the ecu is actually using with BE
its best to upgrade to tunerpro as its much simpler and faster
Unread postby david claflin » Thu May 25, 2017 8:18 am
decipha wrote:its best to upgrade to tunerpro as its much simpler and faster
OK, is the tunerpro.net the best place to get the latest version from? It's been a long time since I used it last.
david claflin
Unread postby SlowBox » Thu May 25, 2017 8:42 am
There's a link to TPRT in the downloads section of the home page.
SlowBox
Advanced Tuner
4r70w, 3.73
GT-40P heads
Stock cam
9.7:1
65mm TB
Decapped injectors
Single 70mm snail
U4P0/U4P2/CBAZA
TunerPro v5
Moates QH v1.6
Unread postby Mach1fun » Mon Sep 04, 2017 3:33 pm
It looks like the A9L2 base calibrations was updated last week, but I don't see a link to it to download it. Am I missing something?
Mach1fun
Name: Anthony E. Stinnette
Vehicle Information: 1994 Mustang GT
Unread postby decipha » Mon Sep 04, 2017 7:26 pm
where u see that?
Unread postby Mach1fun » Tue Sep 05, 2017 7:44 am
Oops, I guess I misread it, the GUFX xdf has been updated not the A9L2 base tune. So 12/08/2016 is the latest tune version?
Mach1fun
Unread postby decipha » Tue Sep 05, 2017 11:43 am
prob so i know i hadnt done anything with it in a good while
Unread postby JETFAST » Sat Sep 30, 2017 4:19 pm
i downloaded the newest a9l2 and the load scale next to the tables reads 0.00 threw the rpm range. am i missing something?
JETFAST
Unread postby decipha » Sun Oct 01, 2017 1:20 am
the latest gufx xdf
Unread postby 89fast5oh » Fri Apr 13, 2018 9:39 pm
Does the A9L2 retain the factory A9L adaptive fueling functions?
I drove around my Mustang with a 351W, 30lbs injectors and "calibrated" mass air meter for 14 years with A9L and only had complaints about hot starting and some low RPM bucking.
Once I change the 8 items referred to in the A9L2 page, and dial in FUEL and AIR will the system act very close to the A9L programming in regards to drivability?
Are there items in the A9L2 programming that increase performance, but cause a decrease in the smoothness/ease of operation compared to that of the A9L?
89fast5oh
Vehicle Information: 1989 LX. 408W 10.7:1, FTI hyd roller .622"/.608" int/exh, AFR 185s, Edelbrock Victor EFI 5.8, 47lb injectors, 75mm MAF & throttle body, 1 3/4" long tubes, 2.5" full exhaust, TKO600, 4.10s.
Unread postby decipha » Sun Apr 15, 2018 7:27 pm
yes
should be significantly better
no
Unread postby 89fast5oh » Sun Apr 15, 2018 8:00 pm
decipha wrote:yes
no
Thank you. Direct and to the point.
89fast5oh
Unread postby 89fast5oh » Mon Apr 16, 2018 7:48 pm
My engine has no EGR passages or AIR pump and the equipment is gone.
What is required to disable those in the A9L2 code so it doesn't throw a check engine light?
When reading through the parameters it seems like the A9L2 uses EGR signal for a significant amount of spark and fuel.
Will this be a problem not having EGR/AIR/SMOG?
89fast5oh
Unread postby decipha » Tue Apr 17, 2018 11:55 am
pfehp is the egr enable / disable switch a value of 2 as the comments say disables it, its already disabled in the a9l2
smog pump is called the thermactor, theres a switch to disable it and in the a9l2 its already disabled
nope none of that is required other than for emissions
Unread postby 89fast5oh » Tue Apr 17, 2018 5:15 pm
decipha wrote:pfehp is the egr enable / disable switch a value of 2 as the comments say disables it, its already disabled in the a9l2
Nice. Thanks.
89fast5oh
Unread postby 89fast5oh » Wed Apr 18, 2018 8:22 am
I should have also asked, is the Canister Purge included in the thermactor? I know if I disconnect the purge solenoid it will turn on the check engine light.
89fast5oh
Unread postby decipha » Wed Apr 18, 2018 8:23 am
no canister purge is not part of smog
you need the purge
Unread postby 89fast5oh » Wed Apr 18, 2018 7:39 pm
decipha wrote:no canister purge is not part of smog
you need the purge
Being young and foolish I removed the canister 15 years ago, I think I might have even cut the line off behind the passenger wheel. I always just left the purge solenoid plugged in as to not get a check engine light.
I do have the canister in a box somewhere. Is this a item I should think of putting back on the car?
If the canister has been removed can it be disabled in the A9L2 so it doesn't turn the check engine light on?
89fast5oh
PreviousNext
