I Screwed Something Up ( SOLVED )
Unread postby Bad86capri » Tue Dec 31, 2019 6:10 pm
My setup is 306, Twisted Wedge heads, B3 cam, ported RPM II intake, 4" custom air intake, 80mm C&L with a tuner tube. I had the fuel dialed in last year and decided to pull the engine to freshen up the gaskets and have some head work done. Well i finally got the car back together and the fuel is way off! The changes made are as follows.
I had the heads cut to get 54cc chambers bringing my compression from 8.9 to 10.1 (roughly)
I changed the intake from a ported systemax to a ported RPM II
I changed the air intake setup from a cast aluminum C&L elbow to 4" custom piece. My MAF stayed the same.
I changed the TB from a 70mm to a 75mm
Is it normal to have a dramatic change in the maf curve with changes ive made? Another issue ive noticed is my hegos are not switching normally, meaning hego2 hardly switches and hego1 switches but not in a consistent manner. I'll post a couple short logs i took today. Any ideas would be appreciated.
Bad86capri
Vehicle Information: 86 Capri T-Top. Oxford white, grey trim and canyon red interior. 306 with twisted wedge heads with 54cc chambers, Anderson b3 cam, Edelbrock RPM II intake, Ford Racing 80lbs inj., c&l 80mm maf, BBK 75mm tb, longtube headers. Im currently using a plx wideband mounted in the driverside header. Tuning with moates quarterhorse and Tunerpro.
Re: I Screwed Something Up
Unread postby Bad86capri » Tue Dec 31, 2019 6:21 pm
Well i just over the log again and it looks like the TPS sensor is not working. Is it possible for the TPS to not work and still be beable to drive?
Bad86capri
Unread postby decipha » Tue Dec 31, 2019 10:53 pm
yea it can run without a tps
how can your maf stay the same if u changed the inlet pipe?
Name: Michael Decipha Ponto
Unread postby Bad86capri » Wed Jan 01, 2020 9:45 am
I meant my maf meter itself is the same. I'm using the same 80mm C&L meter and sample tube as before. The one thing I noticed in the log playback was the load was peaking at 2.00 forcing the eec to command full rich which in turn would make car stumble and bog. I'm thinking the TPS not working is cause of most of these problems but not sure to be honest.
Bad86capri
Re: I Screwed Something Up ( SOLVED )
Unread postby Bad86capri » Wed Feb 12, 2020 3:00 pm
TPS was the issue.
Bad86capri
Unread postby decipha » Wed Feb 12, 2020 3:11 pm
no it can't be TPS has no affect on load or fuel
