2003 full size PCM from a Taxi
I have located a 2003 full size luxury sedan PCM. The Ford number on it says it came from a taxi. It is 3W7A-12A650-BMA. Not that it matters because it will get reprogrammed anyway, did the taxis also have PATS switched off in them the same as PCMs out of police cars?
Re: 2003 full size PCM from a Taxi
What is a full size pcm?
part number is useless. Cross reference the hardware code on the homepage under supported ecus to see what it is.
why would pats matter ?
Full Size Luxury Sedan EEC-V.. RZAS0 Strategy MPC-195 Hardware
Some were CNG so verify.
My guess is it will work just fine.
http://www.obdtester.com/ford-ecu-updat ... 12A650-BMA
Thanks 034v...
