I have one of my friend he own 2016 Mustang GT Manual Transmission stock with TB closing issue in 4th gear. No error code and nothing wrong with it after Ford dealer checked the car. They mentioned maybe you need to tune the car with your gear ratio 3.15 as it was 3.31.
We tried to have it tuned without toching the TB table and the issue still there. Any way how to fix it from tune and make sure rpm will not stall.
Throttle body close issue at WOT
- Vehicle Information: 2001 Mustang Roush Stage 3 Supercharged with Build Engine
Re: Throttle body close issue at WOT
Log it and see what the problem is.
We datalog it and we found that at WOT before 4000 rpm the TB will close but if we go in 3rd gear and pass the 48 mph and shift to 4th and WOT immediately it will work fine with no TB close. Its kind of strange.
log your torque source and see what's causing the tb to close
re-write the stock tune back to it and see if it still acts up
I already tried logging the torque source and at WOT when tge issue accured and throttle close the torque source was reading 13 and shift to 15 and get back to 13. It was doing it back and forth. So, torque source 13 is "Tip in Torque Control" and "OSCMOD". So to fix the issue should i disable the Tip in Active Switch or what?
Sounds like its calculating a tip in. Make sure you don't have any scaling changes or corrupted values in the driver demand, effective throttle area or predicted throttle table normalizing / scaling functions.
