Got a friend with a 93 F150 that has a 5.0 and a 94 Bronco ECM in it. His ECM has IVY0 on it and using the search box in the downloads page I was brought here. Would it be safe to use? Also, would the Quarterhorse be able to read the stock bin?
Thanks!
Will AHAC2 work with IVY0?
- Vehicle Information: 1993 Mustang 5.0 LX
- B cam
- 76mm C&L with tube for 24 lb injectors
- Old type Ford Motorsport 24 lb injectors
- In fender CAI
- Catted X-pipe
- 2 chamber flows
- 3.73:1 gears
- T5
- T4M0 computer (originally an auto car converted to 5 speed with A9P computer)
- All else is stock
Re: Will AHAC2 work with IVY0?
yep yep
- B cam
- In fender CAI
- Catted X-pipe
- 2 chamber flows
- 3.73:1 gears
- T5
- All else is stock
Thank you.
