Non-specific forum for discussing hardware issues such as wideband faults, MAF, Injectors, etc..
by Mnorman1964 » Tue Nov 05, 2019 2:20 pm
I have an eecv 2000 model with an rpm out pin that's not being used. Does anyone know if that is compatible to drive an aftermarket tach?
Mnorman1964
- Premium Member
- Name: michael norman
- Vehicle Information: 1969 F100 Truck SWB
5.4 2002 32V DOHC engine from Navigator
4r100 trans
MQAIO EECV stock
10:1 comp
Stock Cams
Seimens 80lb injectors
Long tube headers
PMAS MAF
Stock Heads
Twin Turbo
80mm aftermarket throttle body with stock TPS
Boss Coyote Intake with custom adapter plates
Return type fuel system with high volume EFI pump
wbo2_UegoAem
- Other Vehicle(s): 2003 F150 FX4
5.4L stock everything
Quarterhorse with TunerproRT
by decipha » Tue Nov 05, 2019 5:10 pm
if its not used it prob doesn't have the tach output hardware present
in any case im not sure it would be the same signal the aftermarket tach is looking for
- Tooner
- Name: Michael Decipha Ponto
- Vehicle Information: Supercoupin' x10
91 4r70w swap - Skarlett
- Other Vehicle(s): Others:
95 Beretta - Delores
08 Grand Prix - Tara
06 Chrysler 300 AWD - Sharifa
12 Explorer - Rystacia
by 034v » Wed Nov 06, 2019 7:28 am
try a MSD tach driver
Created the TPRT XDF's below in my spare time. More to come as time allows.
Let me know if you need one.
1996 Lincoln Mark VIII CDBA4
96-97 Ford Car CDAN4
97-98 Lincoln Mark VIII CMBA0/CMAI3/6/7/9
93-95 Lincoln Mark VIII CZAJL
87-92 Lincoln Mark VII SFI-SD3
034v
- Name: GLB
- Vehicle Information: 1996 Lincoln Mark VIII, TPRT Tuning with my own XDF
- Other Vehicle(s): 1989 Lincoln Mark VII, TPRT Tuned with my own XDF
- Vehicle 3 Information: 2009 Ford F150, Work Horse, SCT Tuned by me
by jsa » Fri Nov 08, 2019 4:44 pm
You would need to ask the tach manufacturer if their product supported the eec tach signal.
You would be wise to put a multimeter on that tach pin to check for a signal.
Another interface solution.
https://www.diyautotune.com/product/axm ... 0b2dce18c9
Cheers
John
- Hacker
- Name: John
- Vehicle Information: Escort RS Cosworth
EEC-IV GHAJ0
ANTI, COSY, QUIK or CARD
SMD-490, SMD-190
by Mnorman1964 » Mon Jan 27, 2020 11:33 am
Found a cheap solution that works. This guy took real good care of me and matched me up to the right part. Hooks up to one of my cop coil feed wires. Cost less than $40
https://www.ebay.com/itm/COP-DIS-TACH-ADAPTER-convert-COP-or-DIS-pack-ignition-to-any-4-8-cyl-Tach/142495590237?hash=item212d66275d:g:clwAAOSwkERb~MSA
Mnorman1964
- Premium Member
4r100 trans
MQAIO EECV stock
10:1 comp
Stock Cams
Long tube headers
PMAS MAF
Stock Heads
Twin Turbo
wbo2_UegoAem
Return to General Hardware
