96 Ranger SVO
96 Ranger SVO
Unread postby decipha » Fri Dec 27, 2013 3:22 pm
I was trying to tune a 96 Ranger yesterday but kept having an issue with the exhaust manifold glowing cherry red at idle
I dumped 34 degrees in her at an 1100 rpm idle and she still went cherry red
AFAIK it appears to be an SVO setup out of a thunderbird complete with manifold and all, only difference from being bone stock is that its a 2.5 stroker with single plug heads and a little porting, and since he got the wrong 2.5 stroker crank he had to use the factory 96 2.3 block, has a set of dished autotec/racetec pistons we had cut, 60lb injectors and an 80mm mark8 maf, otherwise its a bone stock SVO engine
we're still using the stock 96 ecu and the dual coil plugs are wired in parallel to the coil
any thoughts on the glowing primaries are appreciated
BTW, this little engine is quite stout for being such a small displacement engine, im quite impressed on the performance with only 89 octane fuel at that
Re: 96 Ranger SVO
Unread postby decipha » Mon Dec 30, 2013 11:11 pm
well we figured out the issue unfortunately it took out a rod in the process, live and learn, gratefully nothing else got hurt and the stock rods are cheap so after a new bushing, a lil polishing, and a new bearing, all is well
the culprit to these ignition issues are the dual coil setup, since we wired them in parallel we were getting some cross firing, so now we're looking for a new ecu with provisions for a single coil like most are but it has to be compatible with the single camshaft pickup which is rather different than ive seen on 6cyl and 8cyl fords
i tried using a cdan4 but that was a no go, apparently the cam sensor doesnt play well
Im open to any/all suggestions, it has to stay eec-v for the obd-II crap
and most importantly it has to support the single pulse cam pickup
Hopefully one year of the ranger had a single coil
Re: 96 Ranger SVO
Unread postby 85GT » Tue Dec 31, 2013 12:18 am
Why do you think the cross firing caused the manifold problem? If it fires a cylinder that is later in the cycle, don't see why it would bother that cyl. Unless there was unburned fuel and it fired a cyl finishing it's power stroke?
85GT
Advanced Tuner
Re: 96 Ranger SVO
Unread postby decipha » Tue Dec 31, 2013 2:01 am
the way the 96 ranger is setup theres 2 ignition coils for a total of 8 spark plug wires
the factory head has 8 plugs 2 per cylinder
the svo head has only 4 total 1 plug per cylinder
We tied both of the coil connectors together since we only have 1 coil to get the engine to run correctly otherwise it just doesnt run smooth when running on only one coil connector
the ecu appears to be alternately firing the coils or some kind of funky jazz cuz it just doesnt want to do right, but it only does it at some special times it seems
In any case it just isnt right so we will be replacing the ecu with something thats not designed for dual coil firing... hopefully
Re: 96 Ranger SVO
Unread postby haroldk » Tue Dec 31, 2013 8:22 am
SVO/Turbocoupe/Merkur folks use the DIS on single-plug heads and just use a single coil pack. I think most of them use a PE or LAx EEC-IV when they do it, but if it's the same DIS system, I'd be a little surprised if you couldn't do the same thing. I'd check around on turboford.org and see if you can dig up some information there.
I was planning on doing the DIS conversion when I had my XR4Ti and never got around to it, but the conversion was pretty well sorted out and very few people ran the dual-plug head on turbo cars.
haroldk
A+ Contributor
Name: Chris Kachelmyer
Vehicle Information: 1984 Porsche 944
Ford 5.0
CDAN4/ZXA5
Quarterhorse
Re: 96 Ranger SVO
Unread postby decipha » Tue Dec 31, 2013 12:27 pm
the 96 range uses edis with the 35 tooth reluctor and dual plug heads with dual coils
the engine has to stay edis because it has to stay OBD-II compliant
it does have the single plug svo heads on it pretty well ported as well
Re: 96 Ranger SVO
Unread postby haroldk » Tue Dec 31, 2013 12:37 pm
OK, that makes a lot more sense. For some reason I thought they switched away from the Lima before that. You could run 4 single coils instead of coil packs and be totally baller.
haroldk
A+ Contributor
Ford 5.0
CDAN4/ZXA5
Quarterhorse
Re: 96 Ranger SVO
Unread postby decipha » Tue Dec 31, 2013 1:12 pm
yep thats what i want to do but there still lies the issue with the cam sproket, im not sure how the ecu will play with that, imma take a look through cdan4 and see if i can figure out a way to get the single pickup cam sensor to play nice
Coil on plug would be preferred though
Re: 96 Ranger SVO
Unread postby haroldk » Tue Dec 31, 2013 1:41 pm
I thought the Lima cam sensors were like the Windsor cam sensors. If you can't get that one to work, couldn't you machine a wheel to fit behind the aux shaft pulley or cam pulley and mount a sensor that will work with what you need?
haroldk
A+ Contributor
Ford 5.0
CDAN4/ZXA5
Quarterhorse
Re: 96 Ranger SVO
Unread postby decipha » Tue Dec 31, 2013 2:50 pm
sure i can but that would require me to do work
Re: 96 Ranger SVO
Unread postby haroldk » Tue Dec 31, 2013 2:55 pm
Yeah, it'd be a hell of a lot easier swapping to a different ECU. :)
haroldk
A+ Contributor
Ford 5.0
CDAN4/ZXA5
Quarterhorse
Re: 96 Ranger SVO
Unread postby decipha » Tue Dec 31, 2013 3:28 pm
precise
Re: 96 Ranger SVO
Unread postby haroldk » Tue Dec 31, 2013 4:11 pm
One thing I will caution you about is that the later Lima blocks suffer from core shift and the front of #1 can be pretty thin. I don't know exactly when that started happening. I know for sure it was when they switched to the small journal cranks. One of my friends cracked the cylinder wall at 450 whp on a 2.5 stroker.
haroldk
A+ Contributor
Ford 5.0
CDAN4/ZXA5
Quarterhorse
Re: 96 Ranger SVO
Unread postby decipha » Tue Dec 31, 2013 4:39 pm
that sucks, thanks for the heads up, guess we should probably reconnect the waste gate
Re: 96 Ranger SVO
Unread postby lowranger96 » Sat Jan 11, 2014 9:39 pm
for cam sensor you can use a 94 california cam syncronizer or you can bolt the stock cam sensor on the valve cover to read the cam gear.
for coil i was almost positive that both coils fired at the same time and that you could just run one of them and disconnect the other. i could be wrong though.. i assume the newer crank sensor is on it too?
1996 - 2.5 CP Flattops, Billet Crower 5.2 rods, Stock head bolts, Felpro 1035, Turbo VC, P&P BV Head, 2277 Cam/spring, Custom Log/Tial MVS, HE351, FMIC, FLH2, ID1000s, HPX Blowthrough, Binary Editor, E85
lowranger96
Vehicle Information: 96 ranger 2.3 turbo
Re: 96 Ranger SVO
Unread postby decipha » Sat Jan 11, 2014 10:03 pm
the engine was already together and running
We reused all the stock 96 stuff with no issues
we tried running with only 1 coil connector but the engine wasnt happy
We tied both the connectors together in parallel and thats when it threw a rod (cross fired) as soon as we loaded the engine
with only one connector hooked up the engine doesnt seem as responsive as when both are connected
As soon as the engine gets dropped back in imma see if i can figure out the coils
Re: 96 Ranger SVO
Unread postby lowranger96 » Sat Jan 11, 2014 10:16 pm
It could be done, but just like pre 98 4.6/5.4L mod motors you would have to wire them in series instead of firing them independently. I'm pretty sure there are guys over on turborangerforum that have run the single plug head with the obd2 ecu so ill see what i can dig up for you
my buddy ran this and said he just ran one coil pack and it ran perfectly fine. how are you running the crank and cam sensors?
lowranger96
Re: 96 Ranger SVO
Unread postby decipha » Sat Jan 11, 2014 10:48 pm
Using the stock 96 block cam sensor crank sensor and ecu
Re: 96 Ranger SVO
Unread postby lowranger96 » Sat Jan 11, 2014 11:22 pm
it should run fine with just one coil.. everyone that ive talked to that ran a single plug head said that is how they did it.. they just unplugged the 2nd coil
lowranger96
