2.3 Turbo BE 2012.
Re: 2.3 Turbo BE 2012.
Unread postby TheElementOfOne » Mon Nov 18, 2013 3:30 pm
Nothing other than the speed density swap. I cleaned and flowed the injectors, ensuring they were flowing 34~35lbs, and then speed density swapped. Originally using the PC1 (5speed), I did the wiring swap to the 87-88 pcm. (Lb3 and 8UA) both show the same issues.
Other than that just a cone air filter, wide band, ported manifold, open down pipe and a 255 walbro pump. All except the pump were on the car with the VAM setup and had no issues other than being a bit lean every now and then like most VAM cars.
TheElementOfOne
Vehicle Information: 1985 thunder turbo coupe, SD swap, Stock.
Vehicle 2 Information: 1993 mustang 2.3T swap w/ Mods.
Unread postby decipha » Mon Nov 18, 2013 5:04 pm
hmm interesting
i know nothing about the sd code on those ecu's
can u fail the map and verify the tables are working then?
Unread postby TheElementOfOne » Tue Nov 19, 2013 12:18 pm
Hate to be a newb, but what are you referring to as far as fail the map?
TheElementOfOne
Unread postby decipha » Tue Nov 19, 2013 12:24 pm
set the minimum frequency for a reliable map signal to max
or set the maximum frequency for a reliable signal to 0
that will set a map fault and cause the ecu to use failure management
Unread postby TheElementOfOne » Tue Nov 19, 2013 1:04 pm
I will try it when I get home. Thanks for the help.
TheElementOfOne
cron
